My key is not recognized
Old 09-03-2017, 11:38 AM
Kevin Twitch's Avatar
Kevin Twitch
Kevin Twitch is offline
I had my battery out for quite some time. When I put in a brand new battery my key was not recognized and my truck will not start.
Old 09-04-2017, 08:02 AM
pawpaw's Avatar
pawpaw
pawpaw is offline
Welcome to FTE.
When you removed the battery, did you have the ignition switch turned on, or did you turn the ignition switch on while the battery was out?
If you have more than one key, will the system recognize the other key/s?
If it'll recognize the other keys, use them & the procedure in your owner manual to try & reprogram the acting out key.
If no joy, or you don't have more than one key, use or come by the inexpensive ELM scan tool, running FORScan diagnostic software on the viewing device of your choice as discussed here https://www.ford-trucks.com/forums/1...-scantool.html & have FORScan query the PATS anti theft system for trouble code clues & post up All trouble code Numbers it finds.
The latest version of FORScan can now work with PATS & maybe can enable you to reprogram keys, if you don't have more than one key.
If you don't want to do that, then call a trusted locksmith that has the equipment to cut & program new keys. Have him do a spare/so you have 3 programmed keys, in case you loose one in the future, you can buy another key & program it using the owner manual procedure.
If you don't have the owner manual, one can be down loaded at no cost here. Owner Manuals | fleet.ford.com
Also it would be helpful to add the year, engine, tranny cab model, ect, vehicle info to your signature, as different years had different PATS systems & it can help members diagnose & give diagnostic, or repair advice on our vehicle woes, if they can read how the vehicle is equipped.
A bunch of thoughts to get you started, let us know how it goes.
Old 09-06-2017, 11:53 AM
spooktn's Avatar
spooktn
spooktn is offline
There is also a fuse that powers the PATS system.I think it is in the Power Distorbution Box under the hood,,,,you might want to check that fuse,,,,maybe Pawpaw will post you a (search wiring link),,,,mine is not working for some reason
Old 09-12-2017, 08:30 PM
pawpaw's Avatar
pawpaw
pawpaw is offline
Well Kevin, how is the acting out key trouble shoot going, 136 curious minds would like to know.
Old 09-19-2017, 12:50 PM
CBB9M's Avatar
CBB9M
CBB9M is offline
If the key is not Stratec (ie, OEM) then there is a very real chance you will have problems. Since the OP does not tell us what he is driving, I will guess it's got PATS, otherwise, ignore this post.
RV Tow'n Truck
1999 to 2016 Super Duty
10-28-2016 08:08 PM
EXv10
03-04-2014 09:10 AM
JF94
1997 - 2003 F150
08-19-2010 06:35 AM
04expo80f250
1997-2006 Expedition & Navigator
12-15-2007 03:33 PM
dvsmnstr
05-17-2005 08:01 AM
Quick Reply: My key is not recognized
