2004 6.0 Running Extremely Rough..
Had a lifter take out my camshaft, purchased a remanufactured 6.0 from Ashevillengine. While the engine was out, a lot of things were replaced including:
-oil cooler
-standpipes
-ARP studs
-ICP sensor
-IPR sensor
-Front cover assembly
-FICM Harness
-EGR delete
-All 8 injector o-ring set
-HPOP Gaskets (old HPOP, no STC)
-8 new glow plugs and harness
-#1 & #4 fuel injector
I get the truck back, and i noticed it has an intermittent problem where it starts up and runs like absolute hell, sounds like misfire, truck is shaking, etc. The crazy part is when it started that way, I could immediately turn it off and it would start like normal seconds afterward. I needed the truck for the week to finish some projects, so i decided to run it out. After three days it finally called it quits and the FICM would no longer buzz the injectors, creating a no start. I replaced the FICM power board, it will buzz the injectors again. As of now, it will only start with prolonged cranking and the starter feels like it has to "walk" the engine up to operating speed. When the engine gets going it is in that very rough shaking state as well. When i tested the starter by itself it spins great. The starter is about two months old.
PIDS:
KOEO:
FICM Main : 49.5
FICM Logic : 12.0
FICM Vehicle: 12.0
Voltage : 12.2
ICP Volt: 14.8
MAP : 14.4
Coolant: 67
IA2: 67
EOT: 69.4
EBP: 14.8
When i got it to start in its sluggish state, here's the pids i recorded.
ICP: 4374 (at start) 1000 @ 1000 rpm
Ficm Main : 48.5
Ficm Logic : 11.5
Ficm Vehicle : 13.5
ICP Volt : 23.8
EBP : 22
HPR : 22.3
Voltage: 14.0
MAP: 15.0
EOT : 120 ( before i shut it down)
VGT: 63
DTC's:
P0113
P0407
P0488
P0671
P0675
P1000
P1102
P2288 (Replaced ICP yesterday, thought i cleared this code but it is back.)
Sorry for the long post, if you guys can wrap your heads around it, I haven't found my unique problem online yet
EDIT: Pulled IPR, had three small piece of debris, no tears or indents, replaced screen anyway.
You need to post IPR% With ICP
Also it's probably but typo but ICPV operates from 0-5.0 volts can you verify those numbers you can't have 23+ volts without a sensor error or gauge error
Are you using SGII?
P2288 - When the actual pressure is greater than a specified maximum pressure (27.5 MPa)
Injector Control Pressure Too HighD*dD*P0488Exhaust Gas Recirculation Throttle Control Circuit "A" Range/PerformanceD+d dD*P0407Exhaust Gas Recirculation Sensor "B" Circuit LowD*d dP0113Intake Air Temperature Sensor 1 Circuit High (Bank 1)G*g gD*d dM*J*E*e eUIAT [AI]P1102Mass Air Flow Sensor In Range But Lower Than ExpectedD*dM*MAF
I agree with above statement go over harness Lots of electronic Caius
was this work done in a shop??
Yes the shop yanked out the engine and replaced it, I was told I would need a new wiring harness soon, but man I didn't think it was THAT soon!
There's a few more things to consider, I have the intake out, so the P1102 Is the MAF disconnected, P0113 IAT1 is unplugged. I can go plug that all back in but I know it won't make a difference. EGR is deleted, I believe that's the cause of 407,488
I had my values wrong on the SG2, corrected numbers are as follows:
KOEO
14.8% IPR
.23 ICPV
0 ICP
Starting/Running
4374 ICP (settled to 1000)
83.8% IPR (settled to 25.0)
2.00 ICV
Somewhere in the ballpark of 650-700 RPM, it will die if no throttle is given.
I will order the engine wiring harness today. I also noticed that after the prolonged cranking, the dash will give you the beep, and only THEN i noticed the RPM gauge doing anything.
Early years are heavily dependent on MAF
And he needs to plug in the egr valve to harness for verification
The truck electronics should be tested close to stock as possible not torn apart
