Was driving to work about 4 miles into my travel rolled around corned and she died..... tow bill and cps she fired rite up. Ran at idle in drive way because I was a little leary for about an hour left drive way went 2 miles went to pull in to store died again.another tow bill and 2 more cps still won't start rpm is only like 200 when cranking but sounds like a lot more.the wts.light works batteries are pretty new cps in new please help
Yes it is and it was a little low on oil but it's been a lot worse she leaks a little.I don't know why I don't just let her R.I.P. but I have faith she will run again thanks for any help
Open the valve and check for fuel draining from the bowl.
Does the tech move when you cranking the engine?
Do you have a fuel pressure gauge?
Next check the IPR, check the nut, check the connector.
Check the ICP connector, try to start it with the ICP disconnected.
I've drained the fuel bowl 100 times had the ipr in and out 5 times seems to test ok with the hose and air test had the icp in and out plugged in and un plugged no fuel pressure guage
Reason: Not done
