2017 Door handles
Old Aug 31, 2017 | 02:11 PM
diamondbackmike2004's Avatar
diamondbackmike2004
2017 Door handles
has anyone found any metal replacement door handles for the 2017+
thanks
Old Aug 31, 2017 | 06:22 PM
cficare's Avatar
cficare
You may be able to expand your search because I heard the same handle assemblies are used on the 2015-up F150. Are you looking to guard against easy entry? I may order a rear handle assembly to replace the driver's door handle and eliminate the lock cylinder. That also eliminates the proximity unlocking feature, but I've been unlocking doors with a key fob for about 20 years ... why change now?
Old Aug 31, 2017 | 06:33 PM
diamondbackmike2004
yea i feel you. i actually dont have the super whizbang gadgets either.
mostly want them because of how easy it is to just twist the cylinder in the plastic.
I want to keep the driver side lock because its pretty common for battries to get fried in the AZ heat.
Old Sep 1, 2017 | 11:29 PM
ZAR2USA's Avatar
ZAR2USA
You can still jump start truck from underneath by attaching jumper cables to the starter in case both your truck batteries and key battery died.
Old Sep 2, 2017 | 04:02 AM
Tex68w's Avatar
Tex68w
Did this, they still pried the handle out and got in regardless and then you are left with a mangled door as well. Reskin and paint at $4500. *****bags are gonna *****bag, deterrents may keep honest people honest, but if someone is determined they are going to defeat anything you throw at them. I have just accepted that down here in Texas these trucks are a hot commodity amongst thieves and no handle swap, cylinder removal, or aftermarket security system is going to change that. This is the sad reality of owning these trucks.
rewillia
Mar 26, 2019 07:23 PM
Trophy_23
Apr 22, 2018 10:43 AM
masonk
2009 - 2014 F150
19
Jul 18, 2016 07:47 AM
gwcrutch
Aug 9, 2004 10:10 PM
ranolan
Jul 4, 2002 12:36 PM
