FORScan help
Old Aug 31, 2017 | 09:12 AM
mr. grieves's Avatar
mr. grieves
FORScan help
Looking for some FORScan assistance on a 2015 6.7L Lariat. I got everything all hooked up with
Amazon Amazon
and FORScan all installed. It sees the truck and connects, loads, etc. Problem is when I go into IPC As Built or IPC (no As Built Tag) module for example to activate Temperature display for example, the 720-07-01 code set is not listed to edit? I have others there but not this one? Same this when I try to activate the DPF% screen, I open IPC module and 720-07-02 is not there for me to edit? Any assistance appreciated.
Old Aug 31, 2017 | 11:16 AM
Just Strokin's Avatar
Just Strokin
Some items are not on the HS-CAN bus (high speed). Some items are only accessible via the MS_CAN bus (medium speed). You really need an adapter than can access both bus. I would think the IPC would be on the HS-BUS.
Maybe one of the guys will chime in on the issue for you.
Old Aug 31, 2017 | 01:11 PM
System's Avatar
System
Prolocutor
He's got the right adapter for both buss'.
OP, are you in the as built modules? The plain english options are limited.
Old Aug 31, 2017 | 05:02 PM
ZooDad's Avatar
ZooDad
Retired guy fixn stuff
Originally Posted by mr. grieves
Looking for some FORScan assistance on a 2015 6.7L Lariat. I got everything all hooked up with https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Screenshots would be helpful.
Keith
Old Aug 31, 2017 | 08:26 PM
dirthawg's Avatar
dirthawg
Maybe your looking in the wrong section? You need to be in the configuration and programming option (third icon from the bottom along the left side) then open the IPC As Built Data to have editing ability.
Rangerforever
Dec 16, 2019 11:34 AM
Rangerforever
Oct 5, 2018 04:03 PM
Skauber
17
Sep 9, 2015 10:16 AM
edf250
Feb 14, 2010 05:27 PM
So-Cal Sancho
May 26, 2009 07:06 PM
