Replacement Glovebox
Old Aug 28, 2017 | 08:07 PM
52 USCG Panel's Avatar
52 USCG Panel
I bought a replacement glovebox from Classic Haulers several years ago, and just now I'm thinking about putting it in. It seems way too big to fit the space. Any tips? I'm thinking it has to be collapsed in some way. Thanks.
Jim
Old Aug 28, 2017 | 08:31 PM
26tudor's Avatar
26tudor
You have to put it in before you install the heater. Don't ask me how I found this out
Old Aug 28, 2017 | 08:51 PM
FortyNiner's Avatar
FortyNiner
Take the glove box door off as well.
Old Aug 28, 2017 | 09:10 PM
Gicknordon's Avatar
Gicknordon
Also if you put a different heater in than what was in the truck originally and use the existing heater hose holes in the firewall, make sure it actually fits with the glovebox. I made that mistake and now my glove box angles upwards as it goes to the firewall.
Old Aug 28, 2017 | 09:26 PM
ALBUQ F-1's Avatar
ALBUQ F-1
BTDT!
It's also not obvious which side is Up.
Old Aug 28, 2017 | 10:31 PM
52 USCG Panel
So, what side is up? I have the box jammed in now with the seam side (staples) down. That doesn't' seem right. The bottom fits, but not the top and sides. Originally the box seemed too big for the space. Now there is not enough cardboard "box material" to fasten the sides and top in place.
Jim
Old Aug 29, 2017 | 06:11 AM
51fred's Avatar
51fred
I installed it with the seam side down. the two notches slide between the dash and the hinge and clamp it in place. I still haven't been able to install one screw but it seems to work ok.
Old Aug 29, 2017 | 06:23 AM
52 USCG Panel
Rich, wouldn't your installation be seam side (staples) up. The notches are on the opposing side. I was going to try the notches on the bottom next. It makes sense that the notches would go with the hinge bolts. Thanks.
Jim
Old Aug 29, 2017 | 08:08 AM
51fred's Avatar
51fred
Your right, that's what I get for trying to quickly answer at 4am! The sides had to be bowed out to attach which brought down the top but still couldn't line up one hole.
Old Aug 29, 2017 | 09:45 AM
cowdog86's Avatar
cowdog86
I just put one in my 51 F3. The box seemed too small once I got it in. Once I started lining up the holes it all came together and fit just right. It was a bit of a dirty dog getting it in without damaging it.
Old Aug 29, 2017 | 07:25 PM
52 USCG Panel
Thanks everyone. I didn't get a chance to work on the glovebox today, but at least I know what side is up. I should be good.
Jim
Old Aug 30, 2017 | 01:18 PM
bhalemail's Avatar
bhalemail
I put one in my 50 and it seemed like there was NO way it was going to fit but like the others said, once i squeezed it in things started lining up however i had 2 screw holes that had no holes in the carboards(not even anywhere) so i just "made them".
Old Aug 30, 2017 | 02:40 PM
petemcl's Avatar
petemcl
Yes, I made the same mistake.
Old Sep 7, 2017 | 02:37 PM
o7i's Avatar
o7i
I don't know if this would help but I found out, to my detriment, that there are two sizes of glove box. I initially had shallower, wider version and had no chance of fitting it. The correct sized glovebox was still difficult to fit but it may be worth checking the measurements
78 & 87 Super Cab
May 20, 2014 09:14 AM
ejohns06
Nov 13, 2012 10:36 AM
eatont9999
29
Aug 14, 2011 11:00 AM
93F150/302
Jan 23, 2009 09:18 PM
Max E
13
Sep 4, 2008 11:55 PM
