Heater for F 100
on
Check the swap meets for a small box heater. I found one made by the Chupp Manufacturing Company that is only about 8x8 inches with doors that open and openings for defrost for 20 bucks. It works great and doesn't take up much room. Other than holes for the three mounting bolts you have to drill only two holes in the firewall for the heater hose connections. I believe these heaters may even still be available but obviously more expensive if you buy one new. I picked up some A/C tubing at NAPA and ran the defrost hose to my stock defroster ducts. I don't have a good picture of it but you can see it faintly mounted on the inside firewall in this one...
Later man...
I have an old 54 but it doesn't have a connection for the outlet tubes for the defrosters. I am now 12 v so I would need a new motor any way but that is over a hundred bucks. It may still be the best way to go for now. Just need to do something before it gets cold. I don't put mine away just because of winter.
Max E
Max E
heater
I would like a picture for sure if you could email it to me. My email is in my profile or I'll put it here also. mddunlap@peoplepc.com
Thanks
Thanks
on
I used a core from a Explorer, 4.0L, fit really well, I had to adjust the holes in the heater box and the firewall but they aren't really that noticeable...... looks quite stock from inside the cab, even under the hood looks good........best thing it was free... customer insisted his was leaking and wanted it replaced.......hasn't leaked a drop since I put it in in May and it still looks new
on
I think it was a 93 or 94, my rememberer isn't what it use to be they can't have changed too much over the years of 90-95 I would think......
I actually used the stock fresh air heater assembly ....then opened the two hose holes up to form one long hole pretty much top to bottom....you can't see the back of it anyway then I ran the rubber heater hoses thru the firewall to the hard line connections on the core........the core fit good...just never came out quite flush to the front of the heater box...some small strips of high density rubber fixed that.....I think I have some pics somewhere. I will try and find them and stick them in my gallery.
Very simple mod and now I can replace the core easier.....if I can just find my "mod" book where I write down all the "rodded" parts/years/part numbers I have added......haven't seen it since I cleaned the shop
added some pics in my gallery
https://www.ford-trucks.com/user_gal...&albumid=35661
Received 1,353 Likes
on
peakswashere
07-13-2020 09:26 PM
Chris Ko
06-23-2017 06:32 AM
