Electric fuel pump safety switch
Old Aug 27, 2017 | 09:52 PM
lasermike's Avatar
lasermike
So I'm poking around looking for ideas to make an electric fuel pump install safer, meaning shutting it off in the event of a crash and I found this article and more specifically the switch recommended in it.
I'm liking it, I've never been excited about just running power straight from the key nor through a regular pressure switch. The PS-64 switch is specifically designed for use with an electric fuel pump.
This all came up 'cause I'm pretty sure the neighbors are tired of hearing the rusty old truck cranking and cranking and cranking to get fuel into the carb so it can lumber into life.
Michael
Old Aug 27, 2017 | 10:04 PM
Justin73supercamper's Avatar
Justin73supercamper
When I put my electric pump in. I went to the parts store and asked for there book with all the switches. I looked through it until I found a switch with the thread size of wanted and would only come on with 4/7 psi of pressure. I put it in a tee in my oil pressure sensor port. And used a relay run using my coil wire as a trigger. And ran the ground of the relay through the pressure switch. It had not failed me yet and the whole set up with. The switch and relay was inexpensive.
Old Aug 27, 2017 | 10:11 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Great "article", thanks for the link, I like that info alot, especially since I am converting the Bronco to a TBI and ditching the mechanical pump for an electric one.
Old Aug 30, 2017 | 02:28 PM
lasermike's Avatar
lasermike
Make sense, I'd just never thought about in any detail and to find there is a switch that seems designed for the task was interesting.
Michael
Old Aug 30, 2017 | 03:31 PM
meangreen92's Avatar
meangreen92
There are also Inertia Switches which Ford put in most, if not all, vehicles with an electric fuel pump. One of those will stay closed until it senses an impact, at which point it will open, stopping the pump even if your engine continues to run. Simply press the button to reset back to closed.
Cars always seem to have them mounted in the trunk/hatch area, while trucks, at least older Rangers, have them mounted inside the cab near the firewall.
Old Aug 30, 2017 | 03:47 PM
lasermike's Avatar
lasermike
Who could forget the engine shutdown pedal provided for the panicky passenger!
I'm only 6' tall yet could reach that thing far more often than the driver liked.
Michael
Old Nov 3, 2017 | 12:39 PM
77&79F250's Avatar
77&79F250
My subscription got deleted somehow, probably my fat fingers? So I am just re-subscribing...
Old Nov 3, 2017 | 01:09 PM
HIO Silver's Avatar
HIO Silver
On 2000-era F-trucks, the inertia switch is mounted on the outboard side of the passenger side footwell.... $5 from the salvage yards I frequent.
Old Nov 3, 2017 | 03:13 PM
JakeHan's Avatar
JakeHan
https://www.ebay.com/itm/Fuel-Pump-E...YAAOSwcB5ZMh4F
I've never used one of these, but heard good things - it lets the pump run for 3 seconds with key-on to prime up the bowl, then uses tach signal instead of oil pressure to signal on/off. The 3-second on part was what I liked, you don't have to spin the motor to fill the carb back up. But it does cost more -
Old Nov 3, 2017 | 09:52 PM
gstirewalt's Avatar
gstirewalt
I purchased this
https://www.summitracing.com/parts/rfw-cr92
Old Nov 4, 2017 | 03:10 PM
lasermike's Avatar
lasermike
That's the "passenger engine shutdown pedal" I mentioned above. Every time I stretched, I hit the darn thing and shut his truck down. He didn't like it much.
Michael
Old Nov 4, 2017 | 03:33 PM
rougeriver's Avatar
rougeriver
Just purchased one of these! Thanks for the link. I'm (slowly) doing the FiTech EFI with the Tanks Inc in-tank pump / 38 gallon tank.
David
AK FORD GUY
17
Mar 19, 2015 08:29 PM
projectbad78
Electrical Systems/Wiring
Sep 11, 2008 07:55 AM
76CamperSpecial
May 31, 2008 11:35 PM
76CamperSpecial
May 27, 2008 10:04 AM
maharashii
Aug 18, 2003 02:06 PM
