Installing Electric Fuel Pump Safety Switch
Old May 26, 2008 | 08:18 PM
76CamperSpecial's Avatar
76CamperSpecial
Ok, after a bit of research, I ordered the Holley Electric fuel pump safety switch today. It should be in by the end of the week.
While I was at it, I ordered a new oil pressure sending unit since I'd have to take that off anyway and it was less than 10 bucks. I understand that the install will need to be done using a tee off the outlet on the oil pump next to the oil filter (I have a 390). My question is -- what type of tee and threaded nipple should I buy to install it? Is it a stainless steel fitting or is there something else I should find?
Hoping to install next weekend -- going to be much better than the previous owner's switch that is always active with the key. The wiring is currently just wedged into the fuse panel -- not good!
Rick
Old May 26, 2008 | 08:26 PM
SteveBricks's Avatar
SteveBricks
FTE Leadership Emeritus
FTE Emeritus
I just used plain old brass fittings on the one I installed on my old '62 292.
I believe it was 1/8 npt. Never had a problem with it
Good mod for safety purposes.
Old May 27, 2008 | 06:55 AM
fp_5's Avatar
fp_5
Brass fittings is what I used as well, although on one engine I used some extensions to get more clearance.
I didn't know Holley made a safety switch? Most folks don't bother but it's important to put one in. I made my own using a standard automotive relay and a diode. It works great.
Frank
Old May 27, 2008 | 10:04 AM
NOCO77's Avatar
NOCO77
I just used an inertia switch from the salvage yard - all modern fuel-injected vehicles have them. I actually have 2, the other one kills the ignition, and a hidden toggle switch/relay setup activates them both for anti-theft.
fmc400
41
Sep 29, 2023 09:46 AM
xavier9480
13
Aug 21, 2015 09:38 PM
AK FORD GUY
17
Mar 19, 2015 08:29 PM
aldog
25
Mar 22, 2014 07:32 AM
76CamperSpecial
May 31, 2008 11:35 PM
