You mean if the stem is spinning and you can't get the nut loose? Or the nut's off but the taper is stuck in the knuckle? Gotta be the second, just trying to picture it.
Yes, the ball joints are shoved up in those holes good. Years of rust don't help either. On my 1986 F150, I took off the castle nut, turned it upside down, and got a really big sledge hammer to break loose the rust holding it in. It still took lots of banging before she finally let loose. Suggest you try the same.
I mean for breaking the taper. On mine, I hit it with a bfh for 2 hours, pickle fork until it broke, broke a 3 jaw puller, heated with a torch, hit it more with a bfh...the pitman arm puller was the only option that worked.
Get a mapp torch, heat it up to the point that all the crud on it has burned away, then dump a cup of water on it, stick a pickle fork in between the axle and the knuckle, then whack it a few times. It'll come off.
