Ididit Steering Column
Old Aug 24, 2017 | 08:51 PM
Pokee's Avatar
Pokee
Received my 30" steering column with column shift today for my 50 f1. Preliminary test fit with Toyota box and u-joint looks like it will be to short. Shift lever will hit dash unless it has about a 5 1/2" drop, and that will be to low. Will have more time tomorrow to check it out. What length are you using? From what I checked out, 30" was what people were using.
Old Aug 24, 2017 | 09:08 PM
yamagrant's Avatar
yamagrant
Can you bend the shift lever?
Old Aug 24, 2017 | 09:23 PM
Pokee's Avatar
Pokee
I get it mocked up tomorrow and see if I need to go with a longer column. Need to put seat back in.
Old Aug 24, 2017 | 09:35 PM
jniolon's Avatar
jniolon
old and in the way
pokee
mine was too short and needed more so I had to build an 'extension...
http://jniolon.classicpickup.com/col...columnin_a.htm
john
Old Aug 25, 2017 | 06:20 AM
GreatNorthWoods's Avatar
GreatNorthWoods
If I remember correctly, I used a 32 inch column in my 49.
Old Aug 25, 2017 | 10:27 AM
yamagrant's Avatar
yamagrant
On my 56 I used a 32". Good luck.
Old Aug 25, 2017 | 11:26 AM
56panelford's Avatar
56panelford
I used the 30" IDIDIT column on mine with a 3" drop but don't have a column shift..
Old Aug 25, 2017 | 06:36 PM
Pokee's Avatar
Pokee
After checking it out more today I would need a 32" column to make it work. Ididit does not list a 32" in the universal column shift, they have a 33". I will return this to Summit and get a 30" floor shift column and a Lokar AOD Shifter. Thank you for all that replied.
Old Aug 26, 2017 | 07:34 AM
ben73058's Avatar
ben73058
Hey Pokee,
It's good to see another '50 getting saved. Post some pics as you make progress.
We used a 30 inch Ididit with our '50 but our drivetrain set up is different than your's....
351W/AOD with a Mustang II IFS.
Good luck over there in Washington!
Ben in Austin (Currently getting soaked by Harvey)
1950 F1
Old Aug 29, 2017 | 09:39 AM
ImSoQuazy's Avatar
ImSoQuazy
Originally Posted by ben73058
Hey Pokee,
1950 F1
Hi Ben,
May I ask which AOD did you use with your 351W?
Which donor vehicle did you get it from and what year?
I'm riding on a 1978 351W & a C6 but would love LOVE an AOD!
Paul
Old Aug 29, 2017 | 10:51 AM
ben73058's Avatar
ben73058
Hey Paul,
We got a no name AOD then had the insides rebuilt/upgraded
with parts from Baumann Engineering. You want to get one with the "A"
size servo - they came on the V8 donor cars/trucks. We have a fairly robust
engine so we had to have a bit more heavy duty internals.
Ben in Austin
1950 F1 (351W/AOD)
Indybeer
Sep 12, 2018 08:46 PM
lilrobo
23
Jul 19, 2014 07:55 PM
tjdad62
Aug 27, 2011 01:29 PM
wiseguy50
May 15, 2006 12:25 AM
