HELP SHOCKS DECISION
Old Aug 23, 2017 | 07:18 PM
kedricklsb's Avatar
kedricklsb
Question HELP SHOCKS DECISION
I have a 2002 f350 super duty RWD. Its has a 5/7 drop(kit unknown). Im changing the front shocks and notice it has the Monroe(Part number 34684). I have 24 inch wheels on it and over the years it has started to bounce more and bottom out when hitting bumps. i would like to get a nice set of shocks. I heard of the bilstein and belltech shocks. Do anyone have a part number or the recommend extended length, collapses length and travel length of a recommend shock i should use. Any help will be greatly appreciated.
Old Aug 23, 2017 | 07:21 PM
jhl3's Avatar
jhl3
Since it is not stock you are going to probably determine those measurements yourself or take it to a shop that installs shocks and have them take the measurements.
Old Aug 23, 2017 | 07:36 PM
F350-6's Avatar
F350-6
Just an FYI. If it's bottoming out, it's because the front coils are worn, not because the shocks are bad (although they probably are too).
Kit unknown means you'll need to figure out spring measurements or visit a spring shop that can measure and custom order a new set of coils for you. Unless your lowering kit just involves those clamps that limit spring movement and it's using the stock springs.
Old Aug 23, 2017 | 10:12 PM
Colorado350's Avatar
Colorado350
As others have said you're going to have to measure what you need. When you begin looking for shocks give some serious consideration to KYB Montube shocks.
The price is very reasonable, the ride is excellent and they hold a load very well. Although not a big name shock like Rancho or Bilstein they have a very good reputation.
Regarding what you need you may be able to cross reference what you have i.e. Length/ compression
Here's the link to what I installed, NOT what you'll need.
KYB 565100 MonoMax Gas Shock
Amazon Amazon
KYB 565014 MonoMax Gas Shock
Amazon Amazon
Old Aug 23, 2017 | 10:51 PM
timmyboy76's Avatar
timmyboy76
Been there
Hit up...
•stillen motorsports
•belltech
•djm
all 3 companies deal with lowered suspension componants
Old Aug 23, 2017 | 11:47 PM
Keabler's Avatar
Keabler
Keep in mind that shocks won't help it not bottom out. That's a spring issue. Shocks will stop it from bouncing and bottoming out multiple times.
Old Aug 24, 2017 | 07:33 AM
kedricklsb's Avatar
kedricklsb
Shocks recommended
Thanks for all the information. I greatly appreciate it and definitely learned a lot just from those few replies.
Old Aug 24, 2017 | 07:49 AM
Keabler's Avatar
Keabler
That's the cool thing about this group. I learn new things here every day!
Gwilkrrs
6.4L Power Stroke Diesel
17
May 31, 2020 07:14 PM
kedricklsb
Aug 25, 2017 12:35 PM
D-rat
May 16, 2017 07:48 PM
cuda66
Mar 13, 2014 01:34 PM
wizzard351
Offroad & 4x4
Jan 13, 2006 07:52 AM
