So what am I missing?
Old Aug 22, 2017 | 02:10 PM
snorindad's Avatar
snorindad
Originally Posted by Yahiko
I have PDFs of that info.
How far do you plan on going? Want to get the right stuff to post.
Basically from the heads up. Like I say I had it all printed out from before but misplaced it. Thanks
Old Aug 22, 2017 | 05:16 PM
Benchwrench's Avatar
Benchwrench
What about the Injectors O-Ring Kit 3C3Z-9229-AA
(CM-5055)
copper washer included
did I miss seeing the oil rail seals in you list?
Old Aug 22, 2017 | 10:36 PM
snorindad's Avatar
snorindad
(CM-5055)
I have added the injector o ring kits and the oil rail seals. Thanks
Old Aug 22, 2017 | 11:39 PM
Yahiko's Avatar
Yahiko
Band-Aids and Neosporin ointment.
Old Aug 23, 2017 | 12:48 AM
snorindad's Avatar
snorindad
And a new back!!
Old Aug 23, 2017 | 01:09 AM
Yahiko's Avatar
Yahiko
I have been using a sheetrock bench so I am not having to
stand on a step stool. Works very well and the bench goes all
the way across the front so you can move around without
jumping down. On the sides I have been using one of the tire
stands that hang over the tire. Works out well if you have it all
set to about the same hight.
I have the passenger side injectors that need to be done and am not
looking forward to that but it has to get done. The driver side is done
and I did find the bad glow plug. The stupid thing was a dead short.
Talk about loading things down at start up.
Anyway back on topic: I sure wished that Harbor Freight had an
over head creeper. They look handy but the price is a bit high for
the use it would get. Now if I had a shop and was doing it every day...
Old Aug 23, 2017 | 06:42 AM
TooManyToys.'s Avatar
TooManyToys.
Broken record .......
Got the step ladder.
Got the bench.
Best method, pull the radiator, fan, stator and the hood latch, up and close to the motor standing on the steering link.
Old Aug 23, 2017 | 02:06 PM
snorindad's Avatar
snorindad
Is it possible to replace all the lifters without pulling the motor. Looking at it today there is a tube which I believe is called the branch tube coming from the back of the motor.
Old Aug 23, 2017 | 03:01 PM
TooManyToys.
Technically you could pull the heads, pull the trans so you could remove the rear plate, then you can leave the block in the frame while taking out the HPOP tubes to replace the lifters. So it's possible.
Old Aug 23, 2017 | 03:20 PM
Yahiko's Avatar
Yahiko
Jack is right you have to have access to the rear of the engine to get the
branch tube out of the way or you can't pull the lifters in the back.
Old Aug 23, 2017 | 03:31 PM
TooManyToys.
I have previously given this some thought .......
Old Aug 23, 2017 | 03:56 PM
snorindad's Avatar
snorindad
So is it worth it to replace some of the lifters. I ordered lifters but can return them. I am not going to pull the trans and rear cover.
Old Aug 23, 2017 | 04:50 PM
  #28
TooManyToys.
Its kind of a should I replace injectors 1 though 4 or all 8 situation. If in the future #3 goes bad you'll wish you had. If #8 goes bad you wish you didn't bother. It has to be your comfort level.
Old Aug 23, 2017 | 07:35 PM
  #29
Yahiko's Avatar
Yahiko
#5 and #7 are the real PITA ones to do.
Guess what I am doing. Just all #1 and #3 to that list.
All the even ones are in.
Old Aug 23, 2017 | 08:46 PM
  #30
snorindad's Avatar
snorindad
So they magnafluxed my heads no cracks. The next step is to pressure test them. Here are some pictures of #8 cylinder and head gasket. Its the only defect we can find. Not sure how it happened. I am very **** about doing things correctly the first time.
jetact
Mar 30, 2015 10:27 AM
f150crewcab
Mar 6, 2015 03:15 PM
Yahiko
Jan 25, 2014 07:36 PM
Yahiko
Feb 8, 2013 05:00 AM
BRay09
Oct 17, 2012 11:16 PM
