Need starter advice.
Old Aug 21, 2017 | 09:10 AM
SkySkiJason's Avatar
SkySkiJason
Originally Posted by brandon_oma#692
Thanks, What was this starter for originally? I am guessing IH trucks? I may have to add one to the wish list to keep on hand for when mine goes out.
I'm not sure. But, my advice is put your old starter on the shelf for a 'spare' and run the good starter. After 1/4 million miles, I don't have a 'spare' anymore. Lol.
Old Aug 21, 2017 | 09:22 AM
brandon_oma#692's Avatar
brandon_oma#692
Is it a 2 or 3 bolt starter? What I have now is a 2 bolt and one of the holes was partially stripped when I got it. Did not realize when I had the trans out or i would have fixed it then. Used a longer bolt to catch some good threads. Need to put in an insert when I have it out again.
Old Aug 21, 2017 | 09:29 AM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
Difficult to see from the picture on the CNC site, but appears to be 2 bolt...
https://cncfab.us/product-category/p...3/denso-99-03/
Although, if the bolt hole is where the blank is at on the mounting surface of the starter, it could be drilled out and utilized as a 3rd mounting location. Not sure about the orientation of the starter and bolts though, so what I have said could be 100% wrong...
Old Aug 21, 2017 | 09:35 AM
brandon_oma#692
good eye thanks
Old Aug 21, 2017 | 09:38 AM
SkySkiJason
It is 2-bolt. If you have a stripped bolt hole, fix it. Still worried? Add blue loctite.
No need to try to add a 3rd bolt.
brenda maldonado
2004 - 2008 F150
Jan 16, 2018 06:12 AM
Furr308
18
May 5, 2015 10:19 AM
BruteFord
28
Aug 20, 2014 12:33 PM
DIYMechanic
Jun 4, 2011 04:51 PM
01FordCrew
Sep 19, 2009 01:37 PM
