Long start when engine is hot
Old Aug 27, 2017 | 09:20 AM
1972RedNeck's Avatar
1972RedNeck
A lot of my carbed vehicles act the same way. If they sit for less than about an hour, the gas boils out of the bowls and a lot of the vapors remain in the intake. This leads to a flooded condition. Hold the skinny pedal to floor while cranking and it takes right off.
If it sits longer, the gas boils out of the bowls and now I have to crank on it for awhile to get gas back in the bowls.
This garbage they sell us that gets passed off as gasoline is a bit irritating at times. I wish they would either quit the ethanol garbage or go whole hog and offer us E100 so we could build and engine that could actually benefit from the ethanol.
As it is, propane is looking more and more appealing, but finding a place for a tank on a work pickup is hard.
Old Aug 27, 2017 | 01:23 PM
sundug's Avatar
sundug
My 1970 F-350 with 360ci has a Motorcraft D4PE-BGA Carb which hot soaks. I have to hold the gas pedal to the floor to hot start, starts normally when cold. I installed a manual choke and rebuilt the carb. The carb has a spacer under it that flows coolant thru it. I have read a phenolic carburetor spacer may help. Should I leave the coolant piece in place, or remove it to install the phenolic spacer? If I leave it, should the spacer go above or below the coolant manifold? I live in southern central Tennessee. Thanks, Doug
Old Aug 28, 2017 | 07:37 AM
1972RedNeck
I installed the coolant heated spacer to help alleviate icing in the winter time.
Old Aug 29, 2017 | 01:55 AM
KULTULZ's Avatar
KULTULZ
Post
Thanks, Doug
If you use either spacer with one another, they will work against one another. It's either one style or another.
Have you actually experienced icing where you live?
Old Aug 30, 2017 | 06:04 AM
sundug's Avatar
sundug
No, I rarely run it in really cold weather
Old Aug 30, 2017 | 09:17 AM
KULTULZ's Avatar
KULTULZ
Post
Venturi icing is more as a result of high humidity rather than ambient temperature. The incoming air is cooled by the venturi effect and if heavy humidity, the icing may occur.
With that heated spacer (and blended fuel), you are actually hurting yourself (IMO). The carb has to be isolated from engine heat as well as possible.
Old Aug 30, 2017 | 09:41 AM
Diverdan0430's Avatar
Diverdan0430
Alright, we truly lucked out with this storm, just a lot of wind and rain...nothing like what is happening north of us.
So, I have been looking for the phelonic spacer...looking at some older post regarding the same issue I found one that may work with my stock carb, it is from JEGS, Holly 17-72, has a part number of 519-5080. Would this work for my truck? Also from a previous post, some one mentioned picking one up at O Riely's part# 50529. It is a composite material, not the phelonic material. Thanks for any help or direction.
Old Aug 30, 2017 | 10:07 AM
KULTULZ's Avatar
KULTULZ
Either the phenolic or composite (thick) will work. I prefer the phenolic as gasoline will not eat it over time.
Old Aug 30, 2017 | 06:39 PM
rustywheel68's Avatar
rustywheel68
Originally Posted by Tedster9
Also check wet fuel height
I'm in agreement on this one- its possible that after sitting for more than 10 minutes, enough fuel (from a too-high float level) has leaked into the motor that it's flooded. holding the pedal to the floor when cranking will tell you, as that will help start a flooded motor.
the motor is just burning the extra gas (ie- running rich) when you're driving.
Old Oct 16, 2017 | 01:07 PM
derekxj's Avatar
derekxj
Im also having this issue - and essentially drawing almost all the same conclusions as i am seeing here. I believe its either heat soak ( even with my 2" aluminum spacer ), or my floats are misadjusted........ even though i swear i set them both correctly when i rebuilt the carb.
Has any-one completely cured their problem with this yet?
Old Oct 16, 2017 | 02:22 PM
Tedster9's Avatar
Tedster9
Float height bench setting is just to get close, the fuel height needs to be checked. Let it idle for a couple minutes on level ground. Shut the engine off. Pull the carb cover and take a look see at the fuel level in the bowl. Too low and it will lean out at highway speeds, too high and it will run on the rich side and may even flood. Always keep a fire extinguisher ready and available at the shop and on the road.
Old Oct 16, 2017 | 06:23 PM
Diverdan0430
I have a 1in spacer, adjusted my carb and timing. Still having the issue. Gonna rebuild my carb and relocate my coil from in front of the motor, it may be too close to the header. Gonna move it to the top of the motor. Check it out again, hope that helps.
Old Oct 17, 2017 | 08:15 AM
  #28
derekxj's Avatar
derekxj
Im unfortunately running an Edelbrock 1406 and cannot check float height on the fly. In fact - Had the truck not come with this carb, it would not have been my choice. Id prefer a Holley but have already rebuild the Edelbrock and am trying to put the money other places and just get this carb functioning the way it should for the time being.
Old Oct 17, 2017 | 09:04 AM
  #29
Tedster9's Avatar
Tedster9
Hm, yeah you could put a gun to my head and I couldn't tell you how to set up an Elderbrock. But I bet the manual is online. There has to be a way to check.
Old Oct 17, 2017 | 09:19 AM
  #30
derekxj's Avatar
derekxj
There is - You disassemble the carburetor to check - And this is the same way to adjust. Its nowhere near as convenient as having sight glasses and the ability to adjust float levels with the carburetor installed and together.
zdumpor
Aug 22, 2016 09:46 AM
sawyersvintage
Aug 15, 2011 08:54 PM
SuperDutyScaler
Sep 30, 2010 03:04 PM
71 F250 Sport Custom
Apr 26, 2003 11:48 AM
olthunter
Apr 20, 2003 06:25 PM
