Long start when engine is hot
Old Aug 19, 2017 | 03:20 PM
Diverdan0430's Avatar
Diverdan0430
I took my old girl out today to run some errands. She is a 352 w/four speed. When I got back in her after about a 25 mile drive, she was a little long to start. When she is cold, fires right up. Short runs, less that 10 miles or so, haven't really had this problem. But this isn't the first time it has done this. What should I be looking at? She has a new Petronix ignition, coil, wires and plugs. Once its starts, she runs good.
Old Aug 19, 2017 | 03:33 PM
Tedster9's Avatar
Tedster9
Engine cranking - starter RPM - is good I take it, just slow to light off? Does it need a lot of pedal pumping and choke when cold? What is your typical starting ritual when warm?
Old Aug 20, 2017 | 09:44 AM
TA455HO's Avatar
TA455HO
Lead Gopher
Do you have a carb spacer between the carb and the intake manifold? If not - it might be boiling the fuel out of the carb when it gets really warmed up. I noticed you live in Texas. This problem occurs more often when it is super hot out or in hot climates.
You run shorter distances and it doesn't get quite hot enough to do it, but once it passes a threshold and you stop the fuel boils out of the carb and to get it restarted you have to crank it enough to refill the float bowl and passages to get it going again.
Just a hunch but let us know if that might be it. A phenolic or aluminum spacer can sometimes be all that is needed to solve such a problem.
Chad
Old Aug 20, 2017 | 09:49 AM
KULTULZ's Avatar
KULTULZ
Post
Blended Fuel Gasoline and it's inherent problems with an open to atmosphere and carbureted system.
ADDENDUM (Fr.)- (College Word For 2nd Thought)
If all mechanical systems are performing correctly.
Old Aug 21, 2017 | 10:04 AM
Diverdan0430
When the truck is cold, two pumps of the pedal, no choke and she fires right up. When it is hot, and is having the issue starting, it turns over normally, no difference from hot to cold as far as that goes. Just doesn't seem to want to fire and start. I will look into the spacer, see if maybe that works.
Old Aug 21, 2017 | 10:42 AM
Tedster9's Avatar
Tedster9
Ok, that's what I figured. Maybe pull a plug under that condition see if they are fouled or wet with fuel.
"Cold" being a relative term. You're in Texas? Even so with just a couple pumps and no choke required it sure sounds like fuel mixture is pig rich. What do the plugs look like right now? Maybe pull a couple and post pics.
Old Aug 21, 2017 | 11:19 AM
TA455HO's Avatar
TA455HO
Lead Gopher
As far as needing the carb spacer - should be fairly easy to check if fuel is boiling away. Drive it for the 25 miles or so when you have a chance. Wait a few minutes. Then take off the air cleaner and look down the carb throat as you actuate the throttle and see if any gas squirts out of the jets. If gas usually comes out but not in these conditions then you have likely lost all fuel in the float bowl.
If fuel still squirts then that is not it.
Chad
Old Aug 21, 2017 | 06:44 PM
mercury dave's Avatar
mercury dave
poor hot start
I had the same problem with my 65 when I installed a Pertronix coil. Started fine cold but not so fine when hot. I finally figured out that the coil needs 12 volts which it does not get if you use the original wire to the stock coil. The stock coil wants less voltage than the Pertronix. Run a new wire with 12 volts to the coil and I bet the problem will resolve itself. Dave.
Old Aug 22, 2017 | 10:34 AM
AZSCAWPION's Avatar
AZSCAWPION
I'm having similar problems with my 65. On a cold start, 1 pump of the throttle, starts right up every time. After driving and turning engine off, if I restart within 10 minutes, again, no problem starting. However, if I wait longer than 10 minutes, I have to crank and crank to get it running again. If the fuel is boiling out, then why would it start so easily when cold? It's not like the fuel is magically making its way back to the carb just by cooling down. I've added an aluminum carb spacer and there's no difference. Ignition is stock. Have only been running it since May, so not sure if the cooler weather will have any affect.
Based on this thread, I've got a few more things I should check. Starting to get annoying though.
Old Aug 22, 2017 | 11:33 AM
Tedster9's Avatar
Tedster9
I'd pull a plug and look to see evidence of flooding?
It might be a little exaggeration to say this but if the motor starts easily (no choke, no pumping) when cold it's running rich and may run into problems when warmed up. Also check wet fuel height and idle screw adjustment, choke pull off adj. etc.
Old Aug 22, 2017 | 12:19 PM
KULTULZ's Avatar
KULTULZ
Post
It may be that the fuel does percolate w/ heat soak or evaporate (with open fuel bowl vent) during a long shut-off period and it may be that you have one hell of a good mechanical pump that either does not allow quick bleed-down or refills the carb bowl quickly. The fuel in the bowl may percolate but not get to the stage where it is forced out of the bowl or vaporizes out of the fuel bowl vent. Is your EVAP connected and/or functioning?
An aluminum spacer will not stop heat transfer. It has to be phenolic or composite,
Six or eight?
Old Aug 22, 2017 | 12:55 PM
AZSCAWPION's Avatar
AZSCAWPION
Makes sense. I'm gonna recheck the carb adjustments. Also, holding pedal to the floor while cranking should help by allowing more air into the mix if flooding is the problem.
Gotten too used to fuel injected engines that I've forgotten half the crap I used to know.
Old Aug 22, 2017 | 01:01 PM
AZSCAWPION's Avatar
AZSCAWPION
Six or eight?
More things to consider. Thanks.
To answer your questions though
6 or 8? 8-390
EVAP? On a '65
Old Aug 22, 2017 | 04:43 PM
KULTULZ's Avatar
KULTULZ
Red face
6 or 8? 8-390
EVAP? On a '65
Reading disability on my part...
Old Aug 24, 2017 | 06:18 PM
Diverdan0430
Gonna check that out as soon as this hurricane passes. Thanks
