Sponsored by: Real Truck
Lsd to locker
Old Aug 23, 2017 | 12:06 AM
rusty 91's Avatar
rusty 91
Originally Posted by projectnitemare
Do you homework before buying. A mechanical locker isn't for everyone. Definitely adds more traction and less parts to wear out but the handling characteristics are lousy when driving a snow covered road at speed. If you're set on a locker get one. A lunch box style won't fit in a limited slip carrier. That leaves you with replacing the clutches in you current one or pull the carrier. If you pull the carrier scrap the lunch box idea and get new unit whether it's a true locker or a helical style limited slip like a trutrac that has no clutches to wear out. If if want to keep the factory stuff, restack the clutches so it alternates friction and steel rather than how the factory does it. It will grip harder. Some will argue there's less engagement of the steels on the axle that way but I have never heard of it failing.
Thanks man....that was a really good response
kidwagon
Jan 9, 2010 06:15 PM
86sixbanger
Offroad & 4x4
31
Oct 18, 2009 10:51 PM
slinger34
Mar 26, 2008 04:40 PM
BII Plow Truck
Bronco II
Mar 3, 2007 01:13 AM
Tdvjensen
Apr 15, 2003 05:36 AM
