Cleaning EGR?
Old Aug 15, 2017 | 08:20 AM
DeeDubz's Avatar
DeeDubz
Cleaning EGR?
Does anyone have experience cleaning the EGR valve? I need to clean mine just looking for some advice. This will be on a non deleted truck. Thanks
Old Aug 15, 2017 | 09:33 AM
Just Strokin's Avatar
Just Strokin
I have read that some remove it and wash it out. Might do a search and see what you can find on cleaning egr.
Old Aug 15, 2017 | 11:19 AM
radium's Avatar
radium
sop and hot water and new seals don't be cheap they coast $25-60 brother does it all the time diesel mechanic for FORD if it' bad let it soak for a day take care
Old Aug 15, 2017 | 03:21 PM
DeeDubz's Avatar
DeeDubz
how often should this be done?
Old Aug 15, 2017 | 04:22 PM
radium's Avatar
radium
??? when it throws code how do you use your truck ??? a lot of idling will cause that but not when used as a truck working it.Its not something that needs to be touched like air filters
Old Aug 15, 2017 | 11:04 PM
Canadian Dozer's Avatar
Canadian Dozer
I work on heavy equipment, best thing we've found for cleaning the EGR valve and such is oven cleaner.
Old Aug 16, 2017 | 07:46 AM
DeeDubz's Avatar
DeeDubz
anyone have a video on taking the EGR off? I was told you have to drain the cooling system a little.
DeeDubz
6.7L Power Stroke Diesel
Jan 31, 2018 03:22 PM
FMC
Aug 20, 2009 06:00 AM
Lunch Meat
Nov 28, 2007 11:07 AM
dagray3
Apr 16, 2007 06:23 PM
