2002 Ex Driver headlight bulb replacement
Old Aug 11, 2017 | 02:49 PM
aero993's Avatar
aero993
Hello,
Checked the tech folder, what is the secret to replacing the driver side bulb?
Thanks
Old Aug 11, 2017 | 03:59 PM
EXSwap's Avatar
EXSwap
Originally Posted by aero993
Hello,
Thanks
If memory serves, the best way I found to do it was rotate the round "keeper" and pull the whole assembly out, slide the "keeper" down the wire, remove the clip from the bulb (which can be stuck a bit and kind of a pain), replace in reverse order. Of course I'll have to caveat that with the fact that my hands fit in the hole in the first place....I'm sure there's a name for the "keeper" but I don't know what it is. It's a tight fit, and I think I had to do it all one handed. Certainly was a pain, but no real secret that I'm aware of.
Old Aug 11, 2017 | 06:13 PM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
Good advice given. Do what he ^^ said.
Old Aug 11, 2017 | 09:40 PM
Simps's Avatar
Simps
Keep at it... its a frustrating install, but once you get the bulb/"keeper" in you feel it and know it is solid when you rotate both to the lock position.
Old Aug 11, 2017 | 11:25 PM
aero993's Avatar
aero993
I will give another shot tomorrow, man my big hands are taking a beating.
Thanks for the response.
Old Aug 12, 2017 | 05:22 PM
ford_model'a''s Avatar
ford_model'a'
If you have the dual battery diesel, you can always pull the driver's side battery which opens up the space around the headlight quite a bit.
Old Aug 12, 2017 | 09:30 PM
aero993's Avatar
aero993
Well, I got it done, but boy was it tight.
Ford modela, I started removing the battery. I noticed all the bolts and said lets try squishing your hand first. Thanks for the suggestion though.
Old Aug 14, 2017 | 10:39 AM
unleashd's Avatar
unleashd
I tried, and tried, and tried......But was frustrated with all the scratches and pain. Easier way for me was to just get the whole headlight unit out and put it back on after replacing the bulb. Took me less than 10 minutes. I wish they had left a few more inches of wiring on that pigtail.
AKHunter93
Nov 21, 2015 11:35 PM
Jim859
Jan 4, 2010 12:59 PM
Whit350
Oct 31, 2009 01:28 PM
mifree
Feb 25, 2004 02:59 PM
Gothy
Jan 27, 2004 10:42 AM
