How Hard Does Replacing A Headlight Have To Be?
I purchased some new, brighter headlight bulbs for my '88 F-250. Is it really necessary to remove the batteries in order to have enough room to access everything at the back of the headlight assembly and replace the bulb? That seems ridiculous, but I don't see any other way to do it.
Also, do these headlights work the same as the first gen Powerstrokes where you just unclip the connector, and pull the bulb straight out?
I would agree this could be a fun one, my guess you'll be replacing the parking brake line, especially if you do not use it much ... that's one of the things that IS replaced on mine .... my $ 650 truck may have more than that in replacement parts installed ......
All of the plastic on my 89 is so brittle I dread taking anything apart. Stupid twist collar thing on the headlights broke most of the "tangs" on it when I accidently pulled the socket through it.
When I replaced the headlight switch the dash had broken apart so much I was barely able to get it to hold together. The retainer hook for my glove box busted off so I have to hold the glove box closed with a bungee cord.
Out here on the coast your parking brake shoes can rust onto the drums if you leave it parked too long. Luckily they break out when you apply enough accelerator pedal pressure.
FORDFAN71
1997-2006 Expedition & Navigator
16
03-01-2015 12:42 PM
