Headlight Lenses...98 Expy.....
Old Dec 30, 2009 | 11:42 AM
Jim859's Avatar
Jim859
Thanks guys for all your info with the previous problems and issues i have had with my 98 Expedition.....I'm interested in replacing the headlight lenses on this vechicle....after 240,000 miles they are quite beat up and need replacing....looking for any insight into changing them out.....I have the replacement lenses already purchased and by viewing the existing i'm looking for what i have to pull apart to install the new ones.....Thanks for any info you can pass my way.....Have a Great holiday season....enjoy
Old Dec 30, 2009 | 09:39 PM
Gevans17's Avatar
Gevans17
replacing headlight assembly on 98 Expy
There are 2 metal retainers behind each headlamp assembly. Push them rearward, then pull up to release headlamp assembly. Disconnect electrical connector to bulb socket. . Pull headlamp assembly out.
Old Dec 30, 2009 | 10:06 PM
fiveohpoepoe's Avatar
fiveohpoepoe
Its fairly simple...gevans17 said it perfectly
Old Dec 30, 2009 | 10:17 PM
madsonp's Avatar
madsonp
Here it is in more detail.
Here's the design concept:
The headlight assemblies slide out forward. They are retained in their current location by a set of ridged steel pins affixed in a horizontal position. The pins fit into teardrop-shaped holes that are punched into movable steel tabs located behind the headlight assemblies. Sliding the tabs upward causes the narrow part of the teardrop to move up and release the grip that the tabs have on the pins. You can then slide the headlight assembly forward, turn the light bulb retaining ring that holds the bulb, and remove the bulb from the headlight assembly. The bulb is still plugged into the wiring, and you have to slightly pry away a plastic clip (don't break it off!) to unlock the bulb from the wiring harness while unplugging the bulb.
Now Simplified:
1. Open the hood.
2. Behind each headlight assembly are two black steel metal strips that have an "L" shaped bend. Pull these up while tipping them slightly back (to release a lock). They should move up about 2". They will not come off (while the headlight assemblies are still in place) and don't need to come off.
3. Slide the headlight assemblies forward, remembering that the headlight wiring is still attached.
4. Twist the knurled plastic collar surrounding the bulb socket to release the light socket from the headlight assembly.
5. The bulb unplugs from the socket once you slightly pry away the plastic clip that locks the bulb to the socket. Don't be Superman during this process.
6. Plug new bulb in, clean with a clean lint-free rag lightly dampened in alcohol. The new bulb must be ultra-clean, even from the skin oil on your fingers.
Reassemble following directions 5 - 2 in reverse order.
Old Dec 31, 2009 | 06:47 AM
Jim859's Avatar
Jim859
Thanks
Thanks guys for all the info.....you make it sound very easy....I'll give it a shot today.....Once again Thanks and enjoy your New Years....
Old Dec 31, 2009 | 08:00 AM
outkast_'s Avatar
outkast_
here is a youtube vid of removal
YouTube - Spyder Installation Video: Ford F150 97-03 Projector Headlights
Old Jan 4, 2010 | 12:59 PM
Jim859's Avatar
Jim859
Thanks guys for all the info for swapping out my headlight lenses....It went quick and easy.....also found some info on here of an issues I've been having with the heater blower motor.....seems the resistor and the plug end were both burnt out just as I had read on some post on this site.....Thanks once again.....
