Wet Dog Smell - Ford Truck Enthusiasts Forums
Wet Dog Smell
Old 08-13-2017, 06:34 AM
Rollinstone71's Avatar
Rollinstone71 Rollinstone71 is offline
Rollinstone71 is starting off with a positive reputation.
Wet Dog Smell
So i bought my current 05 from an older gents because the price was right and the mileage was low (83K), one owner rust free Florida truck. He traveled with two large dogs and it had a wet dog smell when I bought it. I figured nothing a new cans of deodorizer wont cure. It's been a month and the funk is still there. Anyone have any success getting rid of old car smells like that.
Old 08-13-2017, 06:59 AM
Oldguyfl's Avatar
Oldguyfl Oldguyfl is offline
Oldguyfl is a splendid one to beholdOldguyfl is a splendid one to beholdOldguyfl is a splendid one to beholdOldguyfl is a splendid one to beholdOldguyfl is a splendid one to beholdOldguyfl is a splendid one to beholdOldguyfl is a splendid one to behold
Quote:
Have the carpet professionally steam cleaned as well as the seats if cloth.
Use Stanley Steamer or eqiv. If that does not work, you might have to replace the carpet.
Finally rent an ozone machine and set it up in there for a couple of days.
Old 08-13-2017, 07:49 AM
Tylus's Avatar
Tylus Tylus is offline
MMNC (SS)
Tylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputation
Pull the carpet and padding. If you have a pressure washer...do that and let it sit for a few days to fully dry
Clean the bare vehicle floor with a disinfectant to kill any residual smells from piddle and whatnot
Been there, done that. Have to do it again to this X (prior had Pits inside all the time)
Don't waste time trying to leave carpet inside the rig. Smell will come back. It will also get activated by dampness even after you think it's all gone. I've learned this the hard way
Old 08-13-2017, 12:22 PM
Nicmike's Avatar
Nicmike Nicmike is online now
Proud Sheepdog
Nicmike has a superb reputationNicmike has a superb reputationNicmike has a superb reputationNicmike has a superb reputationNicmike has a superb reputationNicmike has a superb reputationNicmike has a superb reputationNicmike has a superb reputationNicmike has a superb reputationNicmike has a superb reputationNicmike has a superb reputation
I will add it is not that hard to remove the carpet. You just need some designated down time to park it of a few days/week. Don't be intimidated by removing the carpet.
Old 08-13-2017, 01:59 PM
MDH16 MDH16 is offline
MDH16 is gaining momentum as a positive member of FTE.
Before you spend a bunch of $$ getting the carpet professionally cleaned or ripping it out try this.
My spousal unit left about 2500 wet bottles of water stacked in the back of the truck for three or four days. Carpet got soaked and mildewed. Then I exacerbated the problem by forgetting about some leftover food from a family dinner for, ohhh, a week or two (THAT was a Science Fair Project) let me tell you.
Anyway, the truck developed a truly heinous funk.
Two Steps.
1: Capture Carpet Cleaner. You can get it at home depot. Amazing stuff, follow the directions and that will take care of 90% or everything. Capture is unscented, so it's not just covering up the smell. It's finely ground polyethylene glycol, in conjunction with the activator spray it actually absorbs the crud in the carpet and allows you to vacuum it out. I'm not going to go into the chemistry, but unlike a lot of the stuff you buy at Wal-Mart, Capture actually works.
2: Follow up with a little Ozone generator like this:
Amazon Amazon
It's little, cheap and has a very low output so you want the truck as tight as you can get it. All the windows up and doors closed. Set it to run full blast and leave it for a couple hours. Turn it off let the truck just sit, still closed for a couple more hours then air it out if need be.
If this combination doesn't work, then yeah, I'd say that you are down to replacing the carpet.
MDH
Old 08-13-2017, 06:54 PM
Oldguyfl's Avatar
That little ozone generator is cool and cheap. Thanks for sharing
Old 08-14-2017, 05:08 AM
Guys, thanks for the help. I'll get the carpet cleaned with Capture and then look for the ozone machine. I'm hoping to knock this out next weekend. I'll yank the carpet and blast it from both side if that doesn't work. Thanks again
Old 08-14-2017, 06:01 AM
Oldguyfl's Avatar
If you have the budget and you need to remove the carpet, just put new carpet and backing in for $300. You are going thru all that work to remove it, just replace it. Plus you can change the color if you like. See my cummins build thread as I show it there.
https://www.ford-trucks.com/forums/1...-o-pics-2.html
Starts at post #29
Old 08-14-2017, 10:23 AM
sessland sessland is offline
sessland is a splendid one to beholdsessland is a splendid one to beholdsessland is a splendid one to beholdsessland is a splendid one to beholdsessland is a splendid one to beholdsessland is a splendid one to behold
I bought my Ex from a guy that did animal rescue, owned horses AND had a huge dog that was always in the Ex. Wet dog in a barn anyone?
The smell was so bad it was impossible to drive with the windows up. People wouldn't last more than a few minutes before lashing out in anger at the offending smell.
First I pulled the carpet out and washed it with a powerful cleaning agent and a power washer.
That took away about 20% of the smell I was dealing with.
Then, I spent a long time trying out pretty much anything and everything out there I could come across and google.
These items were a complete waste of time and sometimes introduced more headaches:
Onions - Does nothing to neutralize any odors, but it does give you an idea of what a wet dog eating a hotdog would smell like.
Baking Soda - Does nothing to neutralize and your vehicle will be covered with a super fine white powder much like a scene from "Narcos". Vacuuming up that fine powder took me quite a while
Vinegar - Also doesn't neutralize and it smells very strong in a car with the windows up
I also tried a half dozen or so different odor neutralizers and they never lasted more than a couple weeks.
What finally worked for me was a product called NATURE'S MIRACLE ADVANCED FORMULA - SEVERE STAIN AND ODOR REMOVER.
It was recommended by someone that worked at PetSmart and it did the trick after 2 applications.
Good luck to you and your nose
Old 08-14-2017, 10:57 AM
Thanks SESSLAND, I'll hunt that down and give it a try. I agree with you I think it's embedded in the leather and everything else in the truck as well as the carpet.
Still smell fuel fordboy2 1999 - 2003 7.3L Power Stroke Diesel 17 01-09-2017 09:13 AM
Premium Vinyl Floor NStorm 2017+ Super Duty 20 10-15-2016 08:14 AM
Mildew smell? 418 1997-2006 Expedition & Navigator 2 09-30-2016 11:27 AM
fluid leak anthonym92 1987 - 1996 F150 & Larger F-Series Trucks 15 09-27-2015 04:56 PM
IP Fuel Leak? mechelement Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 11 05-17-2010 01:16 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
