How to replace headlight bulbs?
Old Jan 22, 2004 | 06:05 PM
Gothy's Avatar
Gothy
Question How to replace headlight bulbs?
Hey guys, I just bought some Super White Eurolite bulbs that I want to install on my 97 X. How do I get to those bulbs? Do I have to remove entire lamp? Circuit City charges $20 to install them, but I think if I knew HOW to do it, it would be simple enough. Thanx.
Old Jan 22, 2004 | 07:15 PM
96explorereddieb's Avatar
96explorereddieb
Your owner's manual should have the directions. From the shop manual:
Removal:
Note:
A properly aimed headlamp normally need not be reaimed after installation of this headlamp bulb. A burned out headlamp bulb should not be removed from the headlamp until just before a replacement is to be installed. Removal for an extended period of time may allow contaminants (dust, moisture, smoke) to affect the performance of the headlamp.
1. Check that headlamp switch (11654) is in the off position.
2. Lift hood (16612).
3. Release latch and swing filler panel to left or right.
4. Remove electrical connector from headlamp bulb by grasping wires firmly and snapping connector rearward.
5. Remove headlamp bulb retainer (13N019) by rotating counterclockwise (when viewed from rear) about one-eighth turn and sliding ring off plastic base. Keep headlamp bulb retainer as it may be used again to retain new headlamp bulb.
6. Carefully remove headlamp bulb from socket by gently pulling straight backward out of socket. Do not rotate headlamp bulb during removal.
Installation:
1. With flat side of plastic base of headlamp bulb facing upward, insert glass envelope of headlamp bulb into socket. Turn base slightly to left or right, if necessary, to align grooves in forward part of plastic base with corresponding locating tabs inside socket. When grooves are aligned, push headlamp bulb firmly into socket until mounting flange on base contacts rear face of socket.
2. Slip headlamp bulb retainer over rear of plastic base against mounting flange. Lock headlamp bulb retainer into socket by rotating clockwise. A stop will be felt when headlamp bulb retainer is fully engaged.
3. Push electrical connector into rear of plastic base until it snaps and locks into position.
4. Close filler panel.
5. Turn headlamps on and check for proper operation.
WARNING:
THE HEADLAMP BULB (13007) CONTAINS HALOGEN GAS UNDER PRESSURE. THE HEADLAMP BULB MAY SHATTER IF THE GLASS ENVELOPE IS SCRATCHED OR DROPPED. HANDLE CAREFULLY. GRASP ONLY BY PLASTIC BASE. AVOID TOUCHING THE GLASS ENVELOPE. KEEP OUT OF REACH OF CHILDREN. ENERGIZE ONLY WHEN INSTALLED IN THE HEADLAMP (13008).
Old Jan 22, 2004 | 08:02 PM
Gothy's Avatar
Gothy
LOL, thanks man, I don't think you could have put it any better. Thank you, now I don't have to pay CC 20 bucks to do it.
Old Jan 27, 2004 | 10:42 AM
Mountaineer40's Avatar
Mountaineer40
Oh yea.....did that last weekend. First time a headlight bulb went out. So I just replaced both of the them with a whiter/bluer bulb. Man these things throw some light at night. !!!!!
M40
RockAuto
Vendor Specials, Discounts, Product Announcements & Group Buys
May 25, 2017 02:41 PM
85MOTORSPORTXLT
Oct 17, 2016 12:34 AM
D Sokol
Jul 5, 2015 12:48 AM
stellalola
Escape & Escape Hybrid
Apr 10, 2008 07:29 PM
boss3024me
May 9, 2001 10:56 AM
