Roof Rack - Permanent install - landing pads?
I have a set of Yakima rails as part of my tonneau cover and can install bikes, skis, etc. over the cover but its not long enough for SUP or Kayaks so am looking to use a similar setup on top of the cab. I was looking to see if I could install landing pads on the roof of the truck, and in the roof ditch there is a cover running thru it to make it look nice. I took that cover off and noticed a number of screws that appear to attach the roof to the roll bar or something else. I was wondering if I could remove one of these screws and attach a landing pad into this location, and then re-attach a longer bolt with some silicon to seal it in. I am attaching some pictures of whats under the ditch cap for those interested, and this looks like a perfect area to mount a landing pad to. This way its very low profile, the roof rack can be removed when not in use, and all that is there is the landing pad which stick up about an inch (which keeps the total height around the max roof height since the ditch is recessed and the center of the truck is a little higher than the ditch). I don't know if its possible but I am very interested in doing this.
One other question is does anyone know what the screw/thread pattern is of the screws attached, and what do these screws attach to?
That stud is what holds the clip for the ditch/channel cover. On the 4th picture left side you will see one of the clips.
I personally don't know if that stud could support a nut with landing pad and the added force of the roof rack. Replacing one of the bolts with something else to me appears to be a better path as I'm a little nervous tying into a stud that's only tied into the aluminum roof and not a support.
I have the tonneau cover with rails, and the cover covers up the stake pockets some so that doesn't work well for my application. I'd love to go with the Yakima landing pads so that I can use the same cross bars for the bed as well as roof of the truck (easiest install) as I likely will not need the roof and bed racks on at the same time... but who knows.
Chelle87
Bed Covers, Tonneau covers, Toppers/Canopies & Bed liners
09-23-2019 08:41 PM
tiny1
10-13-2017 12:00 AM
