Low Copmression / Bent Spark Plug
Old Aug 7, 2017 | 05:33 PM
coltonoslund's Avatar
coltonoslund
I rescued this 78 F250 400 from the woods. The land owner said it had been used every once in a while and had a rebuild about 60k ago. I replaced the plugs, wires, cap, oil, oil filter, and rebuilt the carb. It was running okay. A little bit of a shimmy to it. Note #7 wasn't bent with original plug.
1) #6, is that a bad valve or rings? What step is next in testing/fixing?
2) #7 plug, wrong size plugs?
Thanks!
Old Aug 7, 2017 | 06:59 PM
coltonoslund
I may have found the issue
Old Aug 7, 2017 | 08:50 PM
Filthy Beast's Avatar
Filthy Beast
I believe you have found part of the illness.
Looks like #6 intake has been like that fer a spell....note the crusties on the pushrod tip. Also, it seems to be some kind of floaters around the bottom of that same valve spring?
#7 plug....careless install...? Wrong gap fer sure.....hehe. And, what's with the goober snot around plug #4? Sorta looks like that there JB Weld junk....?
Old Aug 12, 2017 | 01:25 PM
LiquidCowboy's Avatar
LiquidCowboy
Possibly debris in combustion chamber on #4, doesn't look like a broke or bent valve. What plug number are those? I run Autolite #25 unless spraying nitrous
LaughingSavage
Modular V10 (6.8l)
Mar 4, 2022 04:54 PM
460me
17
Aug 15, 2019 08:55 AM
1OldFordMan
Feb 14, 2010 08:00 AM
cabldawg
3.8 & 4.2L V6
Dec 23, 2008 07:26 PM
72ford360
Modular V8 (4.6L, 5.4L)
Mar 4, 2007 01:33 PM
