Whiskey Tango Foxtrot
Old Feb 13, 2010 | 03:20 PM
1OldFordMan's Avatar
1OldFordMan
Can someone tell me what this is? Looks like some kind of extension on the end of the plug. Was going to try to do something with Ursula today. This is the missing plug, found it hanging over the steering shaft. According to The Zone, these aren't the right plugs for her anyway. Not sure what they do fit. Tried to take some pictures, cell phone doesn't take very good pictures. Tried to get closeups after seeing the first two.
Old Feb 13, 2010 | 03:33 PM
johndeerestx30's Avatar
johndeerestx30
I believe its a non-fouler for a spark plug.
Old Feb 13, 2010 | 03:34 PM
FORD RANGER's Avatar
FORD RANGER
yes pat,
thats spark plug with a fouler on it! you have an oil problem. take that fouler off and look at the plug!!!!
Old Feb 13, 2010 | 03:38 PM
jr32560's Avatar
jr32560
yup you got some oil problems there in the cylinders
probably a few heat ranges above what should be in that motor
bad-bad-bad
Old Feb 13, 2010 | 04:04 PM
lew52's Avatar
lew52
Havn't seen one of them in a long time , yep its to keep the oil off the plug when you have a bad cylinder....Lew
Old Feb 13, 2010 | 04:06 PM
FORD RANGER
if he does that, he takes the risk burning a hole in the cylinder tho.... or piston...
Old Feb 13, 2010 | 08:15 PM
fishforlife2007's Avatar
fishforlife2007
huh...never seen one of those..
Old Feb 13, 2010 | 09:23 PM
FORD RANGER
i have several times, i've seen diesels do it too....
Old Feb 14, 2010 | 07:27 AM
BigBlueOx's Avatar
BigBlueOx
Naw.....you can't kill a 300.
Old Feb 14, 2010 | 08:00 AM
1OldFordMan
Thanks for the info everybody. Never saw one before & was more lost & confused than I usually am. All I can say is this guy always told me he was a long time FORD mechanic. I certainly hope not. Half the plug wires are covered in electrical tape, the overflow hose from the radiator to the overflow bottle is cut off & missing about half of the hose. This plug does nothing to make me feel any better. Oil doesn't look like it's ever been changed. My niece told me he changed it a few hundred miles ago, few hundred thousand from the looks of it. I have a feeling I'm going to be losing money on this deal. The air filter box wasn't even screwed down on one side & it feels like it's stripped on that side. The intake snorkel tube is gone ( wanted to steal that for Old Rusty ), just open box under the hood. Another thing I'm not fixing. The pos. battery cable has what looks like household electrical wire spliced into it to go up to the battery, The more I look at Ursula, the more I wonder Whiskey Tango Foxtrot this guy was doing. Very glad he never did anything to Old Rusty for me. Don't think I'd trust him to even change a bulb after seeing this mess. Note to self: No more favors for family. You don't need the headaches. Will be replacing the air filter & breather filter, actually not bad considering the shape everything else seems to be in. Dirty enough to be replaced, not full & you wonder how it could even breathe ( like a lot of lawn mowers I've seen ). Doing all that, I might as well throw a new PCV valve in too. Didn't see it when I was there yesterday, didn't look real hard.
helihansen
58
Jan 9, 2018 01:01 PM
helihansen
Ford Truck Parts for Sale
Jan 8, 2013 06:54 AM
helihansen
Oct 23, 2012 06:25 AM
1OldFordMan
Feb 1, 2012 11:54 AM
1OldFordMan
18
Dec 8, 2009 08:08 PM
