Modular V10 (6.8l)
Melted spark plug
Old Dec 24, 2018 | 03:41 PM
LaughingSavage's Avatar
LaughingSavage
Melted spark plug
Well this is a very unusual thing! Did a top speed pull yesterday with my F-250 and when it was done it had a bad misfire. This was what I found.
Just changed them about 10k miles ago, NGK Laser Iridium, Probably my fault for running an 87 performance tune and much hotter coils on stock temp spark plugs but I figured some of you would like to see a little destruction
Old Dec 24, 2018 | 07:04 PM
projectSHO89's Avatar
projectSHO89
What you have there is a cheap aftermarket plug repair kit, probably a Dorman or HeliCoil, that was used to repair a blown plug. Blown again, not surprisingly.
Old Dec 24, 2018 | 07:12 PM
LaughingSavage
Im well aware , I was the one who did the repair when it blew but it didn't blow this time, Just melted inside the cylinder due to spark and heat
None of the plugs should blow, The heads have already been cleaned up. The Heli-coils shouldn't come out except in this case where it was practically welded to the spark plug, Ended up damaging the threads when I wrenched it out though so i had to re tap them
Old Dec 25, 2018 | 06:48 AM
Im50fast's Avatar
Im50fast
I like carnage pics as much as the next guy, so thanks
i pity you though ; for the downtime and repair costs.
someone on FTE had a dramatically melted spark plug recently. I wish I remembered some details.
Something crazy happened in that combustion chamber.
Old Dec 25, 2018 | 07:44 AM
tiffy2000's Avatar
tiffy2000
Check codes to see if it was running lean
Old Dec 25, 2018 | 10:39 AM
LaughingSavage
I did and no codes, All the other cylinders were running fairly lean too. I plan to call 5star and have them add a tad more fuel to the tune. I think the aftermarket coils are actually burning nice and hot. I also need to find a colder plug for this truck which would help greatly
Old Dec 25, 2018 | 08:59 PM
R&T Babich's Avatar
R&T Babich
Timesert carries a helicoil repair insert you might want to check out.
If I've been reading the posts correctly over on the Excursion forum the general consensus is to not use helicoils to repair Triton heads and stick with Motorcraft plugs.
I had #3 blow on our Excur and the Timesert repair has 20k on it - no issues.
Old Mar 2, 2022 | 11:21 AM
BruceJ's Avatar
BruceJ
Burnt plugs
I don't see anywhere here what caused the melt down of your plug. I'm dealing with an '08 6.8 Titan that is melting all plugs. I've been a mechanic most of my 66 years and I'm baffled. The only thing I could possibly think it is would be a crank positioning sensor signaling the computer to stay lit.
Old Mar 4, 2022 | 07:41 AM
Diamnd1's Avatar
Diamnd1
The tunes I have from 5 Star have the option to enrich the fuel mix. I did an update last year with a customized tune and I ran across it in the menu. Maybe an update is needed? I run about 6% richer and when I changed plugs, they looked good.
Old Mar 4, 2022 | 04:46 PM
LaughingSavage
Im still baffled by it honestly. Do me a favor and find the next step coldest plug and give that a try, just for s***s and giggles
Old Mar 4, 2022 | 04:54 PM
LaughingSavage
Not to bash a company but i deleted all my 5-star stuff. After the v10 incident i checked everything for the twin turbo engine I'm doing now. Couldn't find a thing and when i pulled the passenger head off my old long block it had 2 more melted plugs i missed. Later tried the tunes for 6.7 Powerstroke and yikes.... I have since bought software and just decided to stick with my own tuning. I'm not saying their stuff is really bad, but the timing is all over the place. Personal opinion.
markvonn22
Modular V8 (4.6L, 5.4L)
Nov 22, 2015 08:05 PM
newbiemechanic
2004 - 2008 F150
20
Sep 9, 2015 06:20 PM
newbiemechanic
Sep 7, 2015 07:19 PM
AK-Brando
Oct 21, 2012 05:46 PM
cabldawg
3.8 & 4.2L V6
Dec 23, 2008 07:26 PM
