found oil in spark plug
Old Mar 2, 2007 | 10:38 PM
72ford360's Avatar
72ford360
well my friend has a 2001 ford f150 with 97k miles. hes parents bought it brand new and took very good care of it, than they gave it to him when he turned 18. he has given the best care u can and maintenance. full synthetic oil changed every 4k miles, fuel filter changed, antifreeze, everything.he called me yesterday and told me the truck was hesitating and got a CEL light. so i scan and got po 305. misfire in piston #5. i thought it was a bad coil, or fuel injector. so i take out the coil and the plug also. to my amazement the plug came out FULL of oil. in the tip and the threads. theres no leaking gaskets, and i took out other spark plugs and theyre clean as hell. the only thing i think it can be is a broken piston ring and or a worn valve guide . he has money for the worst case scenario but it wasnt in his plans to get a new engine. i told him what i think it could be , but could there be something else?? idk, what else can i check??? or could be? rigth after i cleaned and put the spark plug back in it worked fine and didnt hesitate . but if its burning oil it wont take long to start hesitating again.
Old Mar 3, 2007 | 01:14 AM
LxMan1's Avatar
LxMan1
Does it smoke when running? I would suspect a ring. But it's hard to say for sure.
Old Mar 3, 2007 | 07:53 AM
projectSHO89's Avatar
projectSHO89
If the oil was on the OUTSIDE of the spark plug, then it's not any problem with the rings or valve guides, it's the valve cover seal.
Steve
Old Mar 3, 2007 | 11:13 AM
72ford360's Avatar
72ford360
it was in the inside.
Old Mar 3, 2007 | 12:16 PM
galaxie641's Avatar
galaxie641
Probably blowby, the stem seal problems were all but fixed on the modulars in '95. I'd let the new plug burn out all the oil and keep track of how much it uses in between changes. Mine uses a qt. every 1500 miles but runs fine with no smoke. Might also replace the PCV valve to make sure it isn't sucking up a ton of oil.
Old Mar 4, 2007 | 12:50 AM
72ford360's Avatar
72ford360
i was talking to my friend and he was telling me that a couple weeks ago the oil pressure gauge dropped all the way down then it came up. then a couple days after it did it again and it went up again. it could all this be tied together and what could be wrong???
Old Mar 4, 2007 | 01:33 PM
LxMan1's Avatar
LxMan1
That could be a bad sending unit. Did the engine get noisy when the gauge dropped off?
txchl33
2009 - 2014 F150
Jul 26, 2013 10:37 AM
1fixitman
16
Jan 9, 2013 07:58 PM
bsr2002
Aerostar
38
Apr 16, 2010 09:40 PM
1996pwrstrk
Arkansas Chapter
16
Jul 4, 2008 01:20 PM
JLDickmon
120
Feb 17, 2008 01:14 PM
