Compression Test #'s
Old Aug 7, 2017 | 12:37 AM
Boostingaz's Avatar
Boostingaz
I had some rare down time so I did a compression test this evening and here are the results:
1) 121
2) 119
3) 120
4) 119
5) 120
6) 120
The only thing noteworthy was the #6 plug was very black in comparison to the others. When I have another free evening I do plan to throw on a vacuum gauage and see how it reads. But so far, do these numbers look healthy enough to start throwing on a few upgrades (offy intake, 4 barrel and either the HD, efi manifolds or headers). I was already kind of planning on pulling the motor as I have a RMS leak. So just wondering if it would be money well spent or worth doing anything while its out? Thank you in advance for any advise.
Old Aug 7, 2017 | 07:46 AM
fe390pc's Avatar
fe390pc
I think you have a very good base to work from. I would pull it to do the RMS as it is much easier out then in. You will also be able to clean it better as well. Think about pulling the freeze plugs and hosing out the block to clean any debris out. This also allows you to replace 40+ year old parts.
Old Aug 7, 2017 | 10:41 AM
orich's Avatar
orich
What engine group do you have, an what's it suppose to be??
other then a 6cylinder.
Orich
Old Aug 7, 2017 | 12:21 PM
Boostingaz's Avatar
Boostingaz
Orich
Sorry, it is a 240/6.
I think 150+?
Old Aug 7, 2017 | 12:57 PM
lee's Avatar
lee
Hi,
Just to confirm,... was the choke open all the way and also the throttle?
Take care,
Old Aug 7, 2017 | 05:05 PM
Boostingaz's Avatar
Boostingaz
Originally Posted by lee
Hi,
Take care,
Choke open, but I did not pin the throttle open. I have always heard it does not make much difference.
Old Aug 7, 2017 | 08:06 PM
lee's Avatar
lee
A closed throttle will lower over all readings due to vacuum restriction. More important is 2 have all readings within 10%.....which you have.
Old Aug 8, 2017 | 10:56 AM
Brian1971f100's Avatar
Brian1971f100
X2 on that. Based on the readings you have your at 12% off original spec. Not bad for the age of the motor. I will bet if you do the compression test at WOT it will be better.
Old Aug 8, 2017 | 01:20 PM
CougarJohn's Avatar
CougarJohn
12% off? According to my 1967 manual, a 240 is speced at 150-200 psi on the compression test.
Nonetheless, methinks the numbers are fine for a driver. With the throttle blocked they would be even better.
Bstaff
1997 - 2003 F150
Sep 25, 2015 06:20 PM
green_95
Aug 17, 2015 02:34 PM
Redneck1465
May 21, 2009 11:57 PM
twisted
1978 - 1996 Big Bronco
Jun 2, 2007 12:28 PM
Charger73400
1983 - 2012 Ranger & B-Series
May 13, 2005 11:28 PM
