Is all of the ignition in good condition? If so pull the plugs and check the compression. Then take off the valve cover and make sure the exhaust valve spring is not broken .
Off the top of my head:
1. Remove the Dizzy cap and look at the inside. Look for a "carbon track" from #8 terminal to the base of the carb. it would look like a crack.
2. Could be #8 plug wire. Get a spray bottle with water in it. At night so it's easier to see a spark. Idle engine. Being cautious of the fan, spray the water all over the plug wires. If they are leaking the spark energy to ground you will see the spark. And a snap sound.
3. Check the gap on the plug.
4. Do a wet and a dry compression test on the warmed up engine. Carb opened all the way. Post the results here.
Or just do like my brother did to me, hey come here and hold on to this
Jefffafa has good suggestions. In addition, an easy check is to make sure that the #7 and the #8 plug wires are not next to one another, or parallel in the spark plug loom. Since they fire immediately in order, close proximity of those wires can cause a misfire.
A wet cylinder will have the best compression since the oil adds to a better ring seal that gives it allusion that since it has the most cylinder compression that it's ok N0T.
May be a bad valve guide stem seal that is sucking oil.
Orich
Plug wire. Ohm out what you put in and retest. A couple of k-ohms is the right answer. Or, swap wires and see if the problem follows.
Compression is low but serviceable on a tired old engine. If it is just a driver, keep driving.
The compression looks good to cly #8, I would be worried of # 5 & 7 but at a later date.
Ok wet plug I think it is not firing the fuel in the cly.
You said you replaced the plug & wire.
Have you checked or better just replace the cap & rotor.
When you had the valve cover off to check the valve spring you did not run the motor to see if both valves were moving did you?
I take it you are still running points? If so what shape are they in and what is the dwell set to?
Are you getting spark to that cly? Pull the wire and install a used plug, start the motor and see if it sparks.
If points and dwell is set right I would say a high point on the cam that the points open on is worn down and may not be opening to fire that cly.
Have you checked or better just replace the cap & rotor. Doing that Tuesday
When you had the valve cover off to check the valve spring you did not run the motor to see if both valves were moving did you? Checked and both move correctly
I take it you are still running points? Running HEI for the Ford FE390If so what shape are they in and what is the dwell set to?
Are you getting spark to that cly? Pull the wire and install a used plug, start the motor and see if it sparks. I haven't checked it hot yet but cold it does, when it duplicates missing while hot, I'll burn the fingers...
lol
More of a side thought...
Is the ground wire inside the distributor in good shape? It bridges the electric gap between the points and the fixed plate under the rotor.
