Fuel tank upgrade (give me your thoughts)
2013 F250 short bed with the 27 gallon tank. I plan to move out of Alaska to the lower 48 next year (don't know where yet) and am looking for a better fuel supply answer than carrying a bed full of yellow fuel cans.
Option 1: Replace the OEM tank with a Transfer-Flow 50 gallon tank. Extends range to approximately 1,000 mi. Remains in truck for capacity once moved.
Option 2: Add a 75 gallon auxiliary tank with automatic transfer pump. Totals 100 gallons of fuel for approximate range of 2,000 miles. Would have to remove/sell once moved. Lose half my bed when installed.
Option 3: Add a 75 gallon auxiliary tank with manual/hand nozzle transfer pump. Totals 100 gallons of fuel for approximate range of 2,000 miles. Would have to remove/sell once moved. Lose half my bed when installed.
In my opinion, the aux tanks in the bed, if not used all the time, are subject to contaminating fuel, collecting water, etc beside taking up a lot of bed space. If you are concerned about the one time trip to the lower 48, I'd stick with the low cost yellow 5 gallon can's.
If I were going to spend the $$$, I'd switch to a transfer flow or Titan replacement tank. I struggle with the cost of those, and the fact I cant take it with me however, when I sell my truck and is the reason I have not pulled the trigger. I tend to keep my trucks 5-6 years tops.
Icthus, if it's just temporary, do the yellow cans in the back. I keep going back and forth too as I like to be able to use my entire bed at times, which is why the 5 gal jerry cans work. In the winter I fill them up and put them in the tailgate area and held in place with my extend-a-bed rack for traction. If you are moving far south then you probably won't need that extra weight.
I have a hard time with the price of the replacement tanks and even the still spendy, but cheaper AUX tanks are really semi-permanent and you already have a "short bed" truck. The 100 gal, plastic tank that Braggs talked about it interesting. Maybe Braggs could share where it was bought, how much, etc... Doubt we can get it in the last frontier though.
Sorry to see you leave Alaska.
100 gal
Ours was a simple white tank with a pump mounted on it. They call it a liquid fuel transfer tank now. Lower 48 is easy to obtain but up north might be harder. Still places like Northern Tool and other online retailers have them for a variety of prices (and material types). Maybe there's a retailer up there?
image for reference
https://www.pickupspecialties.com/Delta/img5.jpg
image for reference
Sell the truck and get a long bed.
There are smaller in-bed tanks and for the price of a Titan you could have one custom made. A 50 gallon tank in the bed would only take maybe 12" of it. If you can get a taller tank you can get it down to 8" or so.
My 50 gallon tank in the bed was a Craigslist find. I just bought a cheap fuel pump through Amazon and wired it to an upfitter. I fill the factory tank while I drive, 86 gallons total (76 for you) works great for me. My total set up was pieced together and I've got less than $300 in it. Use it every week since 2011 with no issues.
If you really can't handle a tank in the bed then just go with Jerry cans. I think it's a waste of time and money if you can't get set up and keep it as long as you keep the truck.
[https://www.transferflow.com/fuel-tanks/in-bed
[https://smile.amazon.com/gp/product/...?ie=UTF8&psc=1
