Fuel tank upgrade (give me your thoughts) - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Diesel > 6.7L Power Stroke Diesel
Reload this Page >
Old 08-06-2017, 11:04 AM
Icthus in AK
Icthus in AK is offline
Icthus in AK is starting off with a positive reputation.
2013 F250 short bed with the 27 gallon tank. I plan to move out of Alaska to the lower 48 next year (don't know where yet) and am looking for a better fuel supply answer than carrying a bed full of yellow fuel cans.
​​​​​​Option 1: Replace the OEM tank with a Transfer-Flow 50 gallon tank. Extends range to approximately 1,000 mi. Remains in truck for capacity once moved.
Option 2: Add a 75 gallon auxiliary tank with automatic transfer pump. Totals 100 gallons of fuel for approximate range of 2,000 miles. Would have to remove/sell once moved. Lose half my bed when installed.
Option 3: Add a 75 gallon auxiliary tank with manual/hand nozzle transfer pump. Totals 100 gallons of fuel for approximate range of 2,000 miles. Would have to remove/sell once moved. Lose half my bed when installed.
Old 08-06-2017, 11:35 AM
Braggs's Avatar
Braggs
Braggs is offline
Braggs has a good reputation on FTE.Braggs has a good reputation on FTE.
We used removable 100 gallon auxiliary tanks on our farm. Slide into bed when you need it (to haul diesel fuel out to the fields) and remove the tank from the bed when you don't need it. The tanks had their own pump on it so you can just use the nozzle to refill your factory tank.
Old 08-06-2017, 11:57 AM
PROSTOCK
PROSTOCK is offline
PROSTOCK is gaining momentum as a positive member of FTE.
50 gal in truck is what I want to do. A bit pricey which is preventing it at the moment. OEM tank size is ridiculous.
Old 08-06-2017, 12:35 PM
djousma
djousma is offline
djousma is a splendid one to beholddjousma is a splendid one to beholddjousma is a splendid one to beholddjousma is a splendid one to beholddjousma is a splendid one to beholddjousma is a splendid one to beholddjousma is a splendid one to behold
In my opinion, the aux tanks in the bed, if not used all the time, are subject to contaminating fuel, collecting water, etc beside taking up a lot of bed space. If you are concerned about the one time trip to the lower 48, I'd stick with the low cost yellow 5 gallon can's.
If I were going to spend the $$$, I'd switch to a transfer flow or Titan replacement tank. I struggle with the cost of those, and the fact I cant take it with me however, when I sell my truck and is the reason I have not pulled the trigger. I tend to keep my trucks 5-6 years tops.
Old 08-06-2017, 12:40 PM
cangim's Avatar
cangim
cangim is offline
cangim has a good reputation on FTE.cangim has a good reputation on FTE.cangim has a good reputation on FTE.
I go back and forth on a titan tank, midship models. I take up the entire bed when hauling the rzr.
Old 08-06-2017, 01:06 PM
Dakster's Avatar
Dakster
Dakster is offline
Dakster has a superb reputationDakster has a superb reputationDakster has a superb reputationDakster has a superb reputationDakster has a superb reputationDakster has a superb reputationDakster has a superb reputationDakster has a superb reputationDakster has a superb reputationDakster has a superb reputationDakster has a superb reputation
Icthus, if it's just temporary, do the yellow cans in the back. I keep going back and forth too as I like to be able to use my entire bed at times, which is why the 5 gal jerry cans work. In the winter I fill them up and put them in the tailgate area and held in place with my extend-a-bed rack for traction. If you are moving far south then you probably won't need that extra weight.
I have a hard time with the price of the replacement tanks and even the still spendy, but cheaper AUX tanks are really semi-permanent and you already have a "short bed" truck. The 100 gal, plastic tank that Braggs talked about it interesting. Maybe Braggs could share where it was bought, how much, etc... Doubt we can get it in the last frontier though.
Sorry to see you leave Alaska.
Old 08-06-2017, 02:06 PM
cangim's Avatar
cangim
cangim is offline
For me it is really when I am loaded up with trailer and rzr that I want it. In my use case it has to be either additional stops for fuel or a solution from titan/transfer flow. I like the titan tanks, just not the price...
Old 08-06-2017, 03:35 PM
Braggs's Avatar
Braggs
Braggs is offline
100 gal
Ours was a simple white tank with a pump mounted on it. They call it a liquid fuel transfer tank now. Lower 48 is easy to obtain but up north might be harder. Still places like Northern Tool and other online retailers have them for a variety of prices (and material types). Maybe there's a retailer up there?
image for reference
https://www.pickupspecialties.com/Delta/img5.jpg
Old 08-06-2017, 04:15 PM
ruschejj's Avatar
ruschejj
ruschejj is offline
ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.
Sell the truck and get a long bed.
There are smaller in-bed tanks and for the price of a Titan you could have one custom made. A 50 gallon tank in the bed would only take maybe 12" of it. If you can get a taller tank you can get it down to 8" or so.
My 50 gallon tank in the bed was a Craigslist find. I just bought a cheap fuel pump through Amazon and wired it to an upfitter. I fill the factory tank while I drive, 86 gallons total (76 for you) works great for me. My total set up was pieced together and I've got less than $300 in it. Use it every week since 2011 with no issues.
If you really can't handle a tank in the bed then just go with Jerry cans. I think it's a waste of time and money if you can't get set up and keep it as long as you keep the truck.
Old 08-06-2017, 04:32 PM
Just Strokin
Just Strokin is online now
Just Strokin is a splendid one to beholdJust Strokin is a splendid one to beholdJust Strokin is a splendid one to beholdJust Strokin is a splendid one to beholdJust Strokin is a splendid one to beholdJust Strokin is a splendid one to beholdJust Strokin is a splendid one to beholdJust Strokin is a splendid one to behold
Bite the bullet and get a Titan tank. You won't regret it down the road. I like the idea of the poly tank since it is the same material as the stock Ford tank and NO welded seams that could split if truck is involved in an accident.
Old 08-07-2017, 04:38 PM
TeamMudd
TeamMudd is offline
TeamMudd is gaining momentum as a positive member of FTE.TeamMudd is gaining momentum as a positive member of FTE.
Do you have any pictures of your set up or links to the pump that you used?
Old 08-07-2017, 05:45 PM
ruschejj's Avatar
ruschejj
ruschejj is offline
Gimme a few and I will let you know. Here's the pump and a link to transfer flow. I have the 50 gallon steel tank but I do not have their proprietary pump control system. As I said before, I just got the tank from a previous owner and rigged it to work with an upfitter.
[https://www.transferflow.com/fuel-tanks/in-bed
[https://smile.amazon.com/gp/product/...?ie=UTF8&psc=1
Old 08-07-2017, 09:19 PM
Lawrencew
Lawrencew is offline
Lawrencew has a great reputation on FTE.Lawrencew has a great reputation on FTE.Lawrencew has a great reputation on FTE.Lawrencew has a great reputation on FTE.Lawrencew has a great reputation on FTE.Lawrencew has a great reputation on FTE.
Tank
i love my titan , it's on my 2nd truck now , no issues and no fuss
Old 08-07-2017, 10:33 PM
bobv60
bobv60 is offline
bobv60 has a good reputation on FTE.bobv60 has a good reputation on FTE.
Not much help but I want to share, on another forum the was a member complaining on the size of the fuel tank, only his complaint it was too big and cost too much to fill up.
You just can't please everyone.
Old 08-08-2017, 04:03 AM
Karl4Cat's Avatar
Karl4Cat
Karl4Cat is offline
Karl4Cat has a superb reputationKarl4Cat has a superb reputationKarl4Cat has a superb reputationKarl4Cat has a superb reputationKarl4Cat has a superb reputationKarl4Cat has a superb reputationKarl4Cat has a superb reputationKarl4Cat has a superb reputationKarl4Cat has a superb reputationKarl4Cat has a superb reputationKarl4Cat has a superb reputation
Another vote for the Titan midship replacement poly tank. Love mine...
Quick Reply: Fuel tank upgrade (give me your thoughts)
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
