Hazard lichting stopped working
Old Aug 5, 2017 | 12:57 PM
bart f-350's Avatar
bart f-350
Hello all,
On my 1989 F-350 7.3L IDI all over sudden my hazard warning stopped working.
I have had a look at the fuses and relais, nothing wrong there, and the regular direction indicators works as they should.
any Idea where i should look next?
Is the hazard switch known for such mishap?
Old Aug 5, 2017 | 01:30 PM
tjc transport's Avatar
tjc transport
i ain't rite
probably a bad flasher. there are two in the truck. one you can see in the fuse box, and one on the reverse side that you can not see.
the one on the back of the fuse box is for the hazard flashers.
Old Aug 5, 2017 | 04:33 PM
dixie460's Avatar
dixie460
If it's like the 92+ body styles you can even swap them to test.
Old Oct 12, 2017 | 06:31 AM
bart f-350's Avatar
bart f-350
Well, I had some time to kill today, and decided to attack again this problem.
Two things I found out; 1) there is no second flasher on the back of the fuse panel.
2)The hazerd flasher is between the glove box and the door jamb/ bottom of the "A" pillar
The weird thing thou, is that I started this problem with no functioning hazard flashers, now I found the hazard flasher, and it's working, but now my regular flashers won't work????
can anyone say something helpful?
Old Oct 12, 2017 | 06:56 AM
Stevaroo01's Avatar
Stevaroo01
The problem is most likely the multi-function switch that includes the wiper/blinker stalk as well as the flasher button behind the steering wheel. These are common to fail on our older trucks.
It’s a really easy fix! You can buy a new Motorcraft replacement for around $100, or you can buy aftermarket for under $40. Both will work.
I just had to replace this on my ‘95. Very rewarding to fix since it is so easy!
Old Oct 12, 2017 | 06:58 AM
tjc transport
i ain't rite
89 does not use a multi function switch.
89 has a blinker switch in the column, and a headlight dimmer switch on the floor.
Old Oct 12, 2017 | 07:31 AM
Stevaroo01's Avatar
Stevaroo01
I’m sorry, I missed the year in the original post. In that case, ignore my response altogether.
Old Oct 12, 2017 | 09:34 AM
bart f-350's Avatar
bart f-350
So, I do not really know what I did, but all in all, everything now works as it should.
It might have to do with it's age, and some corrosion here and there, and since I had to pull several connectors to measure, it might be well possible that that restored contact enough to work again?!?!
I'm happy now!
ved0303
Dec 14, 2015 07:48 PM
ozzy_2_me
Oct 12, 2009 07:11 PM
stevetopps
Nov 7, 2007 08:59 AM
carfreak113
1978 - 1996 Big Bronco
Nov 20, 2003 07:31 PM
scanmike
1983 - 2012 Ranger & B-Series
Apr 14, 2003 10:04 PM
