Tail lights inop
Old Oct 11, 2017 | 12:41 PM
adam.hilberath's Avatar
adam.hilberath
Tail lights inop
92 f150 5.0
​​​​​​recently started having this issue. Running lights work, left turn and brake work. No right rear turn or brake. No flash from front right turn. Occasionally front right doesnt come on at all. Dont know if its related to hooking to a junk trailer. Any thoughts? The right of trailer is what was jacked also.
Old Oct 11, 2017 | 04:50 PM
ChRoNo16's Avatar
ChRoNo16
Sounds like a bad ground situation may have either caused bulb issues or damaged the flasher.
they are cheap, try a new flasher first, and check the bulbs while you are at it.
Old Oct 11, 2017 | 05:03 PM
adam.hilberath
Are there 2 flashers? I haven't looked. I plan in swapping to all led stuff soon anyways with new housings on all. I will try the flasher thoigh.
Old Oct 11, 2017 | 05:04 PM
Tranz zam's Avatar
Tranz zam
Check the grounds.
I had a wire chafe in the rear tail light harness, and it caused all sorts of issues. It wouldn't let me shift out of park if the truck was running. I had to start it in neutral lol.
Old Oct 11, 2017 | 08:17 PM
ChRoNo16's Avatar
ChRoNo16
yes, there is a flasher for the turn signals, and a seprate one for the hazards
Old Oct 11, 2017 | 08:20 PM
adam.hilberath
So is there a right turn flash, left turn flash, and hazard flash? Or turn flash wuth both sides on one and hazard flash?
Old Oct 11, 2017 | 10:39 PM
mrollings53's Avatar
mrollings53
There is a turn signal flasher, and a hazard signal flasher. The turn signal flasher is the one you can directly see in the under dash fuse panel. The hazard flasher is in the same panel, but on the back side. The flashers themselves are the same, and can be interchanged.
There are aftermarket flashers that can handle more lamps than the stock flashers. This is useful when while towing a trailer you experience an erratic flashing pattern, or a very fast flashing pattern. I had this problem while using a slide in camper with tail lights, and towing a trailer. I had eight total bulbs running off a can rated for six.
Old Oct 12, 2017 | 08:49 AM
HardScrabble's Avatar
HardScrabble
Temporarily Deactivated
If you read stuff Ford printed you could come to the conclusion that these trucks don't have tail lights.
Don't tap into the taillight wires to hookup trailer lights.
Old Oct 12, 2017 | 09:01 AM
adam.hilberath
I have the T adapter that goes in between the two harnesses at the bumper.
Old Oct 12, 2017 | 09:44 AM
rla2005's Avatar
rla2005
Take the adapter out to see if it got borked when you hooked up to that trailer.
78_f150
Jun 4, 2010 11:36 PM
bubbasinafordf150
Mar 11, 2010 11:00 AM
the peppermint
Feb 11, 2005 11:04 PM
Techie9
Dec 10, 2004 11:53 AM
caperail
Electrical Systems/Wiring
Jan 9, 2003 01:29 PM
