Make sure they are all connected, and not leaking. Good time to replace them.
I saw a few check valves or delay devices attached, they only go one way, photograph them before you disconnect them ever.... (one color on one side, white one the other)
I have 2 tanks and will be installing the vapor can on Monday. My trucks are registered in Yuma AZ. They don't require smog, but at the end of the month I'm moving to Las Vegas NV. Supposedly they are pretty strict.
On the very bottom of the drawing, the; "Line to Intake manifold vacuum"
This line goes to your coffee can, Solenoid side, the line with the "T" in it.
So the complete connection is from the coffee can to the bottom connection on the EGR-Solenoid, DG - Dark Green Wire. (using the vacuum line with the "T" in it.
The top port on the EGR Solenoid Valve goes to the EGR-Valve.
(you can hook these two up now, it won't cause a vacuum leak,,,,yet)
Take the coffee can out, look it over good for rust or leaks.
Blow in both sides to see if there is a built-in check valve.
Then plug one hole, blow smoke in the other hole, check for leaks, swap the plug, blow smoke thru the other hole, in the can, check for leaks.
(There are other ways, like, hold the can under water, I want to see the video)
