Help with charcoal canister
Old Aug 5, 2017 | 03:49 PM
  #31
FadedF350's Avatar
FadedF350
I apologise I'm slightly computer illiterate
The left line now on my coffee can leads to this top vac line, after removing the purge valve that was T connected in. The right coffee can line is the one directly under the top connection, but leads to the rear of this assembly.
Old Aug 5, 2017 | 04:02 PM
  #32
vjsimone's Avatar
vjsimone
No worries, just messing with you, Sandy ask me to stop in and slap you around....
"The right coffee can line" most likely goes to your vacuum Tree or trident Tree..
"The right coffee can line is the one directly under the top connection, but leads to the rear of this assembly" Can you photograph this ?? I don't see what you are seeing...
Old Aug 5, 2017 | 04:07 PM
  #33
vjsimone's Avatar
vjsimone
Is there a vacuum line to your EGR Valve ?
Old Aug 5, 2017 | 04:33 PM
  #34
vjsimone's Avatar
vjsimone
Are there wires going to this "Assembly"?; "rear of this assembly"
If so, what are their color codes?
Old Aug 5, 2017 | 04:51 PM
  #35
FadedF350's Avatar
FadedF350
The right can line runs direct to the rear of that assembly. As for the vac tree it only has my fuel pressure regulator, and a 1/4" vac line that runs to this T attached to the rc fuel line
Top connector is a solid green and a red lower right connector looks to be solid red a white w/r stripe.
Old Aug 5, 2017 | 04:52 PM
  #36
FadedF350's Avatar
FadedF350
As for the smackin me around sometimes it's much needed to get the head right
Old Aug 5, 2017 | 05:00 PM
  #37
vjsimone's Avatar
vjsimone
Ok. that connector goes to the TAB Solenoid (Thermactor Air Bypass )Solenoid).
But I don't understand where the right side coffee can line goes to .
Old Aug 5, 2017 | 05:06 PM
  #38
FadedF350's Avatar
FadedF350
It goes past the vac tree in the center of the manifold and ends right here under the thermo deal you just described
Old Aug 5, 2017 | 05:18 PM
  #39
vjsimone's Avatar
vjsimone
Ok, cool.
The connector to the right, Red/Dark Green wires - this is the EGR Vacuum Regulator (EVR)-solenoid.
Is there a vacuum line or two going to that? Or two...
Is there a vacuum line going to your EGR Valve connected to the intake?
Old Aug 5, 2017 | 05:24 PM
  #40
vjsimone's Avatar
vjsimone
Oh, is there another hose connected to the TAB solenoid (W/R wire) on the other side of the device the coffee can hose is going too?
Should be 2 vacuum ports for each device.
Old Aug 5, 2017 | 05:46 PM
  #41
FadedF350's Avatar
FadedF350
Nothing is currently connected to my EGR valve currently as its missing it's down pipe. As for TAB solenoid I an not connected on the bottom honestly didn't even see the other port till just now.
Old Aug 5, 2017 | 05:56 PM
  #42
vjsimone's Avatar
vjsimone
ok, no worries, right now you don't have vacuum leaks related to the items touched today.
No reason to worry about the EGR-Solenoid (Dark Green (DG) wire) until you decide to fix your EGR Valve.
I do recommend you block off your EGR-Valve with a solid block off gasket.
Old Aug 5, 2017 | 05:59 PM
  #43
vjsimone's Avatar
vjsimone
As far as the TAB, you have another Device with a vacuum line and maybe 2-3 hoses going to it.
Do you see this device?
  #44
FadedF350's Avatar
FadedF350
Well that's the best news I've gotten in the 2years I've owned the truck haha. So with the other TAB vac line mia were still ok?
Old Aug 5, 2017 | 06:03 PM
  #45
vjsimone's Avatar
vjsimone
I hit the buzzer first ! Hey, look at my post before this, answer the Q....
