Tuner? Hybrid injectors for towing and daily driver?
on
I am thinking hard about getting hybrid injectors, maybe 200/30% from Rosewood Diesel, but need a good tuner who is experienced with them to get dialed in for "Baseline", "Heavy Tow", "Daily Driver", and whatever else like maybe economy, performance, etc.
I've read of both successes and complaints, but a lot of the info is older.
I am hoping some tuners have gotten a lot of experience with them and they aren't a mystery or excessive challenge. I would like some recommendations (or solicitations by PM, I think that is okay if I've given request/permission up front?) of some tuners for this effort.
I am looking for both a short term commitment to get them going and a long term if I make changes support.
Ideally, getting something "good enough" for now and at some point meeting up for live tuning, somewhere close to them if needed
I have a Hydra and am not afraid to use it! LOL. I have the USB cable and computer and such, no problem loading tunes and pulling logs and making graphs, stuff like that
I am ready to send my injectors and get the work started on rebuilding and converting them, but I REALLY want to make sure I can find a tuner who is onboard first.
Ideally, I'd like to talk with someone today
Suggestions? Volunteers?
Thanks!
Thanks!
Have you asked Rosewood if they recommend anyone for tuning of the hybrids?
What about the other suppliers of hybrid injectors? I have not done any research on hybrids, so forgive my ignorance on who does or does not sell hybrids.
Asking the retailers who they recommend for tuning is where I would start.
With all that trouble that you are having are you sure that you don't have a major mechanical failure? There seem to be a couple of major problems with engines after long trips lately. I'm thinking that it might behoove you to do a leakdown or compressing test on your cylinders before spending that kind of money.
on
I had an extended conversation with Jim at Rosewood, which was really helpful to me. Helped me make my first and then backup choices. He has a good reputation and took time to understand what I was looking to do.
So I've chosen him as the injector builder and plan to visit his place to pick them up and meet him in person. I'm a handshake guys whenever possible and 3 hrs one way is "possible"
They do list a couple of tuners, but as is customary in this market, the recommendation is to talk to the tuner you think you want to use, make sure he is comfortable with your expectations, and is available to you before ordering injectors.
If I can't connect with the right guy for the hybrids, I'll go to fallback of 160/30 or 160/80 and have more options.
I am looking for a good working relationship, not a "take your chances on who is playing with your tune" and tunes that don't show up or any of that jazz. Someone who inspires confidence in the tunes might be a good way to say it
Make sense?
on
But everything it is doing is consistent with injector failures via orings and internal orings.
So much so that I'm willing to take that chance. I don't think it is a high probability of major internal failure and it was parked before it had a major malfunction, only a few minutes of running from the problem to the garage.
Besides, if it is major internally, I'm tapped. Out of the diesel business
Hopefully it is just the injectors
on
on
If I upgrade the turbo, fuel, oil, transmission, whatever, later, I'm okay with new tunes then, too.
I just don't want to get some "special" injectors, then running around begging for someone to tune them because I didn't plan ahead
Maybe @cletus will weigh in on these?
on
Missed answering this.
I'd like to have more than I have now and be able to use it
Not a smart-alek answer, but now I have to be detuned in Heavy Tow AND get high EGTs that force me to back off the pedal.
I understand boost makes power, but it also makes heat. If we can get more flow, more useable power, with less heat...mostly in the towing department...I think that would be a good start
John, when/as I am building my truck up (slowly, but still getting there) I am shooting for 375 HP total. Absolutely nothing above 400 HP because like you, I want a reliable tow pig. I don't want something I have to tinker with and keep after all the time. I want a strong and reliable truck that will move my house on wheels from parking spot to parking spot safely, quickly and reliably.
I am following your journey very closely as this may sway my thoughts on the 160/80 injectors I have decided on.
Rich is spot on with his words that in a tow tune you should not be seeing high EGT's. When towing my 5th wheel and in the GH heavy tow tune, I cannot get the EGT's to go much past 1150, even if I try. Usually they are right around 1000 going up a grade and 700-800 just cruising. When crusing without a load behind it, the EGT's are near 500-550ish cruising.
Subscribed...
Subscribed...
