Trans replacement- what else to do?
Old Aug 1, 2017 | 12:56 AM
510galaxy's Avatar
510galaxy
So in the near future I'll be pulling my E4OD to replace it with a fresh and beefier unit. While the trans is out I'd like to take advantage of that opportunity to tackle any other jobs that are made easier by the trans being out of the way. I'll renew the engine rear main seal for sure, but what else?
My truck is virtually stock with 155k, so I'm considering a 4" exhaust at the time. Are up-pipes easier to replace? What about a non-EBPV turbo base- maybe it makes little difference, but I figured I'd get the parts early if I thought it'd help.
Thanks for the input.
Old Aug 1, 2017 | 07:42 AM
farmert's Avatar
farmert
If you are still running the stock flat downpipe, replace it with the 3"one from Diamond Eye. The uppies are easier to get to with the tranny out, and if the coin is available get the bellowed ones. Clay at Riffraff Diesel has both items.
Old Aug 1, 2017 | 08:28 AM
helifixer's Avatar
helifixer
I have a fleet of over 50 psd trucks that I work on, I have never changed a rear main seal.
if it isn't leaking leave it. if you think it is leaking check the top of the engine.
bellowed up pipes from Clay at Riff Raff diesel.
3 inch down pipe.
Old Aug 1, 2017 | 09:12 AM
duck fan's Avatar
duck fan
Because racetruck
Have to 2nd both ideas. It isn't your rear main, but a set up bellowed up-pipes would be a good idea while you are there. These are the best I have used in the link below.
Riffraff Diesel Bellowed Up-pipe Kit for Ford 7.3L 94-Early 99
Old Aug 1, 2017 | 07:14 PM
Kingkong0192's Avatar
Kingkong0192
When mine was out I took the time to clean the underside of the truck and paint everything.
Also replace your transmission cooler with a bigger one.
Old Aug 9, 2017 | 09:48 AM
510galaxy's Avatar
510galaxy
Thanks for the excellent suggestions folks!
I neglected to mention that I'll also add a Mishimoto SD trans cooler- the one they just released for 7.3 SDs. Already in my hot little hands.
2fifty
Aug 29, 2017 05:26 PM
rungunner
Jun 15, 2008 11:41 PM
neon4x
Apr 29, 2007 12:27 PM
PilotRob
1978 - 1996 Big Bronco
Jan 16, 2007 09:14 AM
bjoern
Feb 16, 2001 12:43 AM
