6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Delete tune
Old Jul 30, 2017 | 11:21 AM
G-Bo's Avatar
G-Bo
Delete tune
I have 6.4 Power stroke. The truck is deleted. I, not knowing that, tried to install bully dog gt tuner. The truck would not start. I uninstalled and the truck started once. Couldn't restart. Through bully dog support I was able to put the truck back to stock. Still no start. I was told that I have to load up a Delete tune to get the truck back to where it was before I started this fiasco. Will I have success? I had no problems with the truck before I started the tuning mistake with Bully dog. If this does not work what are my options?
Old Jul 30, 2017 | 11:31 AM
Picton's Avatar
Picton
Install the delete tune...it should fire up. If not...tow to Ford dealer for re-flash...then install delete tune again...should work.
Old Aug 2, 2017 | 07:26 PM
DieselDenny's Avatar
DieselDenny
If your sure you are back to stock, disconnect both negative terminals overnight and sleep on it.
Try it again tomorrow.
Denny
Old May 18, 2018 | 05:08 AM
Mike Bradley 013's Avatar
Mike Bradley 013
Where can I get this delete tune and name of it I'm having same issue with my truck
where can I get this tune I'm having same issue with my truck after installing bullydog tuner
Old May 18, 2018 | 05:14 AM
Mike Bradley 013
I'm having the same issue with my 08 ford f250 6.4l desiel with deletes I have bullydog tuner but wont work with truck unless I get the right tune can you point me in the right direction.
Old Mar 1, 2019 | 11:41 AM
ChrisCast's Avatar
ChrisCast
Exclamation
I have had a Bullydog GT tuner in my Ford F-250 for about 6 years and it has fried my entire computer system TWICE. The first time the shop didn't know why but the second time they traced the codes back to the Bullydog GT tuner system. It has cost me $2000 each time to replace the computer.
Removed inappropriate comments.
speakerfritz
Dec 22, 2018 09:34 AM
DGB3
Dec 15, 2015 10:02 PM
F 250 6 liter
May 28, 2010 09:01 AM
borcht warrior
Oct 8, 2008 12:48 PM
ALEXVB22
Apr 27, 2008 10:32 PM
