Steering column swap
Old Jul 24, 2017 | 11:28 AM
540milotalon's Avatar
540milotalon
'95 F-350 4 Door, A/T and the the steering locked up trying to back in a space.
I swapped my '96 with a ZF5 a couple years ago but I believe I read where a steering column out of a Crown Vic will work for A/T trucks.. Not having luck finding the swap thread.
Is this correct? Is there something I need to plan for? Such as the towing shift selector? I'm thinking a car steering column will be better than a truck because people will not have been pulling their selves up with the wheel.
Thanks in advance!
Old Jul 24, 2017 | 01:42 PM
nossliw's Avatar
nossliw
Some of the parts transferred, I highly doubt the entire unit unit did.... it may be luck but a tight colum out of a bronco f150-350 is commonly found for 60-100 bucks on CL in Denver.
Old Jul 24, 2017 | 07:51 PM
krifenbu's Avatar
krifenbu
Almost everything I have learned about our shift columns came from fullsizebronco.com. I believe that is where Steve83 talks about the guts of the column from a crown vic working in the 92-96 Bronco. It has been a while since I have been there.
Kevin
Old Jul 25, 2017 | 08:14 AM
tjc transport's Avatar
tjc transport
i ain't rite
the crown vic column will bolt rite in, the only difference is some of the electrical plugs will need to be changed depending on the year it came out of, same as with the trucks.
Old Jul 25, 2017 | 04:37 PM
540milotalon
Thanks guys! So tjc, If it's a bolt in, is there a problem with the "tow" botton for the A/T?
Old Jul 25, 2017 | 04:48 PM
tjc transport
i ain't rite
no idea what a tow button is. do you mean the overdrive cutoff switch?
if it does not plug rite together, it will only be a matter of changing the plugs on the wires just like you would have to do with other year truck columns, and swapping the steering wheel if you want the truck wheel instead of the car wheel.
Old Jul 25, 2017 | 06:25 PM
z31freakify's Avatar
z31freakify
Even the 99-07 superduty steering column are the same, everything electrical attached to it is different, but swappable.
Old Jul 26, 2017 | 08:37 AM
tjc transport
i ain't rite
yup. pretty much every column made after 92 will interchange between full size car and pickups. the only difference is wiring.
Old Jul 26, 2017 | 08:48 AM
nossliw's Avatar
nossliw
Learned something today! Good to know!
Old Jul 28, 2017 | 11:19 AM
540milotalon
I learned some things too. Been busy working on a Case IH round baler so been away from FTE. Thanks guys, I will be heading to the spare parts yard. Last time there they sold me a working 110V IDM for $20.00 bucks and the ticket said "sensor". You have to make friends at the right time and place. Always keep a spare, right?
Old Jul 31, 2017 | 07:39 PM
540milotalon
One thing folks, what do I have to do if I get a hold of a steering column with the steering wheel air bag intact?
Old Aug 1, 2017 | 07:24 AM
tjc transport
i ain't rite
nothing if you do not want to use it. unless the air bag is hooked up to power it will not work.
Old Aug 1, 2017 | 08:54 AM
mcali2's Avatar
mcali2
good info. I may need to do this.
Siegfried.shelly1970
Sep 23, 2018 09:33 PM
DeanBob
Jan 10, 2014 03:13 AM
Dave58
Apr 14, 2008 04:00 PM
sparky
Apr 11, 2002 06:26 AM
