Steering Column Swap Question
Old Jan 8, 2014 | 11:23 PM
DeanBob's Avatar
DeanBob
Has anyone heard of swapping out your steering column with one out of an LTD? If so, is it a direct bolt-on swap? Was thinking about putting tilt steering in as a nice feature. Has anyone had experience with this? Thanks in advance.
DD
Old Jan 9, 2014 | 02:25 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Doesn't make any difference what year the LTD is, its steering column is completely different.
You can swap in a 1978/79 F100/350 tilt column...as long as your truck doesn't have a 3 M/T. But it's not a direct swap.
All the tilt related parts are obsolete, so that's something to consider. No one has any of the tilt's locking lever NOS and by now most are worn out.
Old Jan 9, 2014 | 05:39 AM
jowilker's Avatar
jowilker
Not to disagree with Mr. Wilson, I do believe the column is one of the more adaptable parts in a vehicle. You have companies like Idoneit & others selling aftermarket columns for years. I pulled and tore down a tilt van column that is much longer, the wheel, the outside of the column is very similar, the wiring is different, but with careful measuring and welding it can be shortened. The shaft is the part that has to reach the horn button and rag joint.
Measure 3-4 times before you do anything, be aware of ign. key location and size, but it might be do-able.
John
Old Jan 9, 2014 | 07:36 AM
NumberDummy
If an A/T, the NSS is located on the steering column 1965/77, on the trans 1978/79.
Old Jan 9, 2014 | 10:12 AM
JEFFFAFA's Avatar
JEFFFAFA
If in A/T, the NSS is located on the steering column 1965/77, on the trans 1978/79.
2X Bill. And also incorporated in that NSS is the back-up lamps. Since the later model columns have no NSS they have no back-up lamp switch.
Old Jan 9, 2014 | 04:58 PM
jowilker's Avatar
jowilker
Might not be a good thing to say here, but I didn't use the NSS, so it's sitting down there on the column collecting dust looking purdy.
The starter will engage regardless of where the tranny shifter is.
John
Old Jan 9, 2014 | 05:30 PM
JEFFFAFA's Avatar
JEFFFAFA
John
Don't let anyone from the "Dukes Of Hazard" borrow your truck John!
Old Jan 9, 2014 | 05:37 PM
jowilker's Avatar
jowilker
My truck can be bought but not borrowed.
John
Old Jan 9, 2014 | 07:09 PM
70-360fe's Avatar
70-360fe
Don't remember what years but some of the older fords have the tilt control combined into the turn signal. I agreed with john, when I did my tilt I found out the shift tube from our old trucks will fit on a tilt head. 80's tilt columns can be re-matched and configured many ways.
Old Jan 10, 2014 | 03:13 AM
jowilker's Avatar
jowilker
I was thinking 78-79. Mr. Wilson sez available in more options but I have only seen them in Larait models.
John
Poison Oil Racing
Jun 21, 2010 09:45 PM
porky2118
Apr 7, 2009 09:05 AM
duke1992lx
Jul 28, 2007 10:34 PM
GammaDriver
Dec 9, 2001 12:18 AM
