shop left lug nuts loose- can i drive it back?
I let a shop do a hub job for me because I am getting old.
Bad idea.
Shop left the lug nuts loose (or over tightened them) and I drove it until all the lugnuts almost came off.
Can i safely drive it back with lugs tightened? They do not appear damaged and the nuts tightened up without thread damage.
Shop manager says no way they did it, that someone must have purposely loosened them or be trying to kill me. Can't wait to speak to him in person.
Thanks!
Bad idea.
Thanks!
Bad idea.
Thanks!
Bad idea.
Thanks!
If you drove them loose, I'd have the studs replaced, either by that shop or another. Yes the hub itself should bear the weight, assuming the correct wheels are on the car, but any lateral stresses from turns, bumps, etc., can stress the studs, and if one breaks, then things can start going downhill quickly. That's another T-shirt I own.
And you don't need a lawyer. Small claims is cheap, generally heard only by a judge, but will take awhile. Only costs you time, while you can get the satisfaction of walking into the crowded service counter and loudly reading your complaint publicly and serving him in front of existing and potential customers. As long as there's a notice, it's not libel.
Both good points.
Kirk, only you can decide how much hassle this is worth.
I had a $1200 big screen Philips TV go bad on me a few years ago during the warranty. I chased a wild goose with Philips for over a month getting a tech to come to my home for 2 or 3 repairs. I ended up writing a strongly worded letter to the CEO in Europe. Of course, I didn't accomplish much, they ended up getting me a refurbished one that died in another month. Luckily, I was able to get store credit at Sam's Club for the TV because the manager was polite, understanding and professional.
Good luck.
Good luck.
I don't know about the WVO or the meth, but the point about the lug holes in the wheel is a good one. If you drove it with all the lugs loose, I would say there is a good chance your wheels are trashed. Check the holes carefully. I would also make sure the rims themselves didn't get "tweeked" / bent in the process. I would want them to buy me new wheels if there was the slightest bit of "egging" of even one hole.
Ford Trucks Rule
02-02-2002 03:35 PM
