1966 - 1977 Early Broncos
Extra Dana 20
Old Jul 20, 2017 | 09:25 PM
dodmort's Avatar
dodmort
Extra Dana 20
I was given a complete trans. And t case for early bronco. I want to decode the Dana 20. I know the 3 speed is a rat. Can I find the build data on the 20 from the tag on back of the t case ?
Old Jul 20, 2017 | 10:38 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Novak...The Novak Guide to the Dana Spicer Model 20 Transfer Case
Is it a T or a J shift? Easy to twin stick for some fun and better abilities.
https://www.tomsbroncoparts.com/cate...-transfer-case
More info Dana 20 Transfer Case - WILD HORSES Early Ford Bronco Parts
More info X2 . Dana 20 Transfer Case - 4 Wheel Drive & Sport Utility Magazine
Old Jul 22, 2017 | 07:22 AM
dodmort's Avatar
dodmort
​​​​​​​appears to be t handle as the shift rods are round then slotted and drilled for linkage. Found that somewhere that I read.
Old Jul 23, 2017 | 01:58 AM
1TonBasecamp's Avatar
1TonBasecamp
I've seen a serial number list that would at least show what year model Bronco it was originally installed in.
Let me see if I can find it.
Paul
Old Jul 23, 2017 | 02:29 AM
1TonBasecamp
Here's a list that Viperwolf1 on another forum put together a few years ago:
dana 20.pdf
That should at least give you the basics about your particular case.
Paul
Old Jul 23, 2017 | 12:44 PM
chrlsful's Avatar
chrlsful
nice wrk (2 both ofya).
What's the astirics mean (in any/all columns)?
Thanks~
Old Jul 23, 2017 | 03:32 PM
1TonBasecamp
Don't see no stinking asterisks!
Actually, I don't. Maybe your viewer is not up to date, or perhaps more likely you just need to expand the screen/columns so that they show the actual characters in the boxes.
I know my Excel does that if you compress the columns or rows too much.
Paul
Old Jul 23, 2017 | 05:37 PM
chrlsful's Avatar
chrlsful
no, chart is fully represented.
Ex: 6th line down (@ 2nd 19"76") it has an asterix.
'S OK, probably "all set" @ this point anyway. Thnx~
Old Aug 8, 2017 | 04:42 PM
sykanr0ng's Avatar
sykanr0ng
** asterisks
Knowing Viperwolf1 from two Classic Bronco forums I would bet the asterisks are where he is less certain of the accuracy.
Icicle
Dec 3, 2005 11:40 AM
monsterbaby
Offroad & 4x4
Oct 31, 2004 03:46 PM
nicolds
Aug 16, 2004 08:26 PM
fordracing27
Nov 3, 2002 07:48 AM
