6.2L V8 Discuss the 6.2L V8
Barking like a exhaust leak when I first start it
Old Jul 19, 2017 | 03:43 PM
papaguido's Avatar
papaguido
my 2016 F250 Super Duty has 8K and the last month or so I have noticed that barking when I first start it and then it goes away?
Old Jul 19, 2017 | 04:10 PM
spongecop's Avatar
spongecop
Semper Fi
warped exhaust manifold? as it heats up it could be going back into spec. I did notice on my 2017 it does sound different when I cold start it ... maybe an emissions EGR type thing????
Old Jul 19, 2017 | 08:37 PM
hot.hogs's Avatar
hot.hogs
2011 F250 with 175K miles, mine makes a similar sound and always has since I got it 4 years ago. I just chalked it up to cold start noises.
Old Jul 20, 2017 | 04:20 AM
Chuck's First Ford's Avatar
Chuck's First Ford
if still under warranty.. take it in.
Old Jul 20, 2017 | 02:38 PM
tjc transport's Avatar
tjc transport
i ain't rite
my 2014 does the same thing. i figured it was the band clamp between the cat pipe and muffler pipe being expanded when cold, and shrinking when it heats up and seals.
Old Jul 20, 2017 | 03:24 PM
Chuck's First Ford
from Ford literature
6.2L 16V SOHC FFV V8 (Super Duty Pickups
and Chassis Cabs)
• Standard on Super Duty Pickups F-250/F-350,
all models
• Standard on Super Duty Chassis Cabs F-350,
all models
• Heavy-duty TorqShift 6-speed SelectShift
automatic transmission is standard on Super Duty
Pickups
automatic transmission with tow/haul mode is
standard on Super Duty Chassis Cabs F-350 with
this engine
Key Features and Benefits
• Flex-fuel (E85)-capable. See the Engineering
Insight on page 2–56
• Large-bore architecture
– Helps improve engine breathing with larger intake
and exhaust valves
– Allows for a shorter stroke design for faster
engine speeds (higher engine rpm) and increased
horsepower
• Single overhead camshaft (SOHC) valvetrain with
roller-rocker shafts allows for enhanced camshaft
design to help provide low-speed torque delivery
• SOHC valvetrain enhances intake and exhaust port
layout and helps improve engine breathing
• Dual-equal variable camshaft timing enhances
the opening and closing of the intake and exhaust
valves during the combustion cycle for a balance of
power, fuel efficiency and emissions
• Two spark plugs per cylinder
– Help efficiently burn the air/fuel mixture in each
cylinder to help increase torque delivery and fuel
efficiency
– Help maintain a smooth idle quality
• Dual knock sensors
– Allow the spark timing of each cylinder to be
enhanced in real time throughout the engine
speed range
• Efficient engine crankcase breathing helps improve
torque capability at higher engine speeds
• Piston cooling jets help improve oil warm-up and
maintain cooler piston temperatures for improved
durability, especially under heavy-duty operating
conditions
• Organic Acid Technology (OAT) orange engine
coolant. See the Engineering Insight
• Fail-Safe Engine Cooling System. See the
Engineering Insight on page 2–57
• Electronic throttle control (ETC) helps deliver
seamless and consistent engine response
• Oil-Life Minder displays the remaining oil-life in the
instrument cluster message center
I BOLD the item.. I think you are hearing at startup...
variable camshaft timing,,,,,, Cycling during engine start up..
Old Jul 20, 2017 | 04:23 PM
tjc transport
i ain't rite
i think he is hearing a slight exhaust leak when engine is cold, just like i am hearing.
on mine it only last for about 1 minute.
Old Jul 20, 2017 | 04:33 PM
Chuck's First Ford
on mine.. I hear a deeper exhaust noise within the headers... for 5 to 10 seconds... right after startup..
Old Jul 20, 2017 | 05:11 PM
tjc transport
i ain't rite
yea, that very well be the cam timing changing.
mine is a definite leak farther back under the truck, in the area of the passenger side seat.
dwh039
6.2L V8
21
Mar 20, 2016 07:11 PM
Buck268
2009 - 2014 F150
Nov 21, 2014 03:53 PM
BassFantasizer
Jan 26, 2012 11:55 PM
jmikeyj4
Mar 29, 2011 08:49 AM
bluesalley
Nov 1, 2002 08:05 AM
