My Ex has developed an occasional ticking sound first thing in the morning. On the mornings with I can hear it, the sound starts within a minute of starting the engine (sometimes at startup and sometimes several seconds later) and continues for 2 or 3 minutes. The ticking increases in speed as the engine RPM comes up, but vacuum, pulley speed, air flow, etc. all increase, too.
My F150 makes the exact same sound and has for about 140,000 miles. (The Ex is a 6.8L, the F10 a 5.4L.) I used to think that it was in the EGR, then the serpentine belt, then a pulley. I finally gave up worrying about it as it hasn't been a problem, only an irritation on some mornings.
Exhaust leak? Does it do it after you truck is warm and you have a warm start? If not, you could have a few broken exhaust manifold studs. They should be easy to check from underneath the truck, do a visual to count each manifold bold head. Minor exhaust leaks essentially seal themselves as the motor heats up, the metals expand and close the gap.
With cracked piston you would also have excessive crankcase pressure due to the blow by.
Not really, the rings will still control the pressure, it's the skirts that normally crack and that is where the clearances are also. It is always more pronounced when they are cold. If the top was cracked you would know it.
Bass, change your oil to thinner 5 w 20 motorcraft synthetic blend.
change your oil filter to motorcraft.
I on a recommendation switched to 10 w 40 at 100K miles, instantly got a ticking noise. Ran it for about 500 miles and switched back. That was 95k miles ago, today at 195k+ my engine sounds like it did when new.
BTW, when i travel to colder climates (freezing or lower) I do get some noises light ticks for about 2-5 seconds. She has been doing this for years and Ford's Best here in Fort Lauderdale claims that that is within Ford specs. (dont know how true that is but again its been the same for years).
I also agree with other post here on the exhaust leak at the manifold, this is a known problem with our V10's. They tick when leaking until everything heats up and expands.
In my case it ticked for just a few seconds when cold, the only way i was able to find where on the manifold it was leaking was by looking for exhaust residue on the engine. Also found 3 broken studs on my drivers side. When I went with Headers all studs were replaced with bolts.
If it were my truck, I would start with and oil change and filter using oem spec.
I would run it for a couple hundred miles then do it again.
(almost like flushing).
I wouldnt be to concerned with pistons etc. at this point. These V10's can take a lot.
I will be in the market for a diesel Ex in a few months just for the hell of it, but I will NOT be selling my gasser. She's my casket!
I hope this helps, Michael
