Sponsored by: Real Truck
P012F code for oil cooler
Old Jul 17, 2017 | 11:40 AM
drjoel's Avatar
drjoel
2010 F350 in my shop today. so, before dismantling the entire top of the motor for this inbred oil cooler job, is there anything else responsible for the P012 engine oil temp issue? it throws the wrench icon and cuts power and i pulled the P012F code.
thanks!!
Old Jul 17, 2017 | 11:56 AM
m-chan68's Avatar
m-chan68
Thermostats on those engines are notorious for failure too. The replacements are updated, but the ones I've replaced have usually set a P00B7 in continuous memory, which will also put the engine into reduced power mode and throw the wrench light, just as well as P012F. Have you monitored your ECT and EOT temps?
Old Jul 17, 2017 | 12:06 PM
drjoel's Avatar
drjoel
thanks! no havnt monitored them individually. the truck does not have the proper gauges, but my otc scanner does live data. not sure if it will do egt though. I can monitor coolant temp.
Old Jul 17, 2017 | 12:09 PM
m-chan68's Avatar
m-chan68
If it can monitor engine coolant temperature, there isn't reason why it shouldn't be able to monitor engine oil temperature too.
Old Jul 17, 2017 | 12:13 PM
drjoel's Avatar
drjoel
but if stat was bad it would overheat coolant. this code i believe indicates engine oil temp has risen to within 15 degrees of coolant temp. ill monitor coolant temp but i think oil temp is the problem...
Old Jul 17, 2017 | 03:19 PM
drjoel's Avatar
drjoel
ill hook it up and give it a try. thanks for help guys. ill keep you posted. Im waiting for a quote from a local shop, but the time lapse video on youtube it looks like a long tedious job. not hard, just lots of pieces and time consuming. anyone here actually done this job?
Old Jul 17, 2017 | 04:45 PM
m-chan68's Avatar
m-chan68
Old Jul 17, 2017 | 04:52 PM
drjoel's Avatar
drjoel
Old Jul 17, 2017 | 06:18 PM
m-chan68's Avatar
m-chan68
Are you the owner of the truck, or the one doing the work? Either way, as you can clearly see, it is a major undertaking. Not a cheap repair by any means.
Old Jul 17, 2017 | 08:16 PM
drjoel's Avatar
drjoel
My friends truck. He has a tractor/farm shop, experienced mechanic. I just diagnosed for him since he is not internet savvy.
i am an ex caterpillar mechanic and have a shop as well, but he is retired and can handle it easily.
passthegaff
Feb 28, 2017 04:35 AM
eric_dean_martin
Jan 31, 2016 07:38 AM
1949ply
Apr 29, 2015 05:19 PM
ZooDad
May 29, 2009 12:58 AM
joe blow
Apr 11, 2009 06:07 AM
