P012f
Old Apr 29, 2015 | 11:18 AM
1949ply's Avatar
1949ply
P012f
2005 F350 6.0L, I was towing my toy hauler when the wrench came on the code was P012F. The dealer has put 3 new oil coolers in and claims to have flushed the cooling system out throughty. After that I installed an external coolant filter, an external oil cooler, EGR delete and flushed the cooling system and a turbo back 4 inch exhaust.
I can only drive for around 50 miles then the P012F comes back. Has anyone got an Idea as what to do except blow it up??????.
Old Apr 29, 2015 | 11:39 AM
WatsonR's Avatar
WatsonR
U sure that code is right? P0112 maybe? I don't see a P012f
Old Apr 29, 2015 | 11:46 AM
shultzaberger's Avatar
shultzaberger
Ford TSB 09-24-3 - "Oil cooler efficiency monitor - DTC P012F stored and wrench warning lamp illuminated when the oil coolers efficiency drops below a specified threshold for a given speed and vehicle load condition."
Have you checked the difference in temp for the oil and coolant temp sensors after a long cold soak? They should be nearly identical.
What are your normal EOT/ECT readings after the truck is fully warmed up? Maybe one sensor is lagging or the other reads to high
after it gets hot?
Have you checked any of the normal wire chafing areas under the hood?
That's about all I got at the moment.
Bumpity bump.
Old Apr 29, 2015 | 12:06 PM
mustang_309's Avatar
mustang_309
If your ECT,EOT and TFT are all within a degree or two after an over night cold soak you may look at replacing the oil filter base as the oil cooler bypass valve may be bad allowing oil to bypass the oil cooler thus not allowing proper oil cooling.
Old Apr 29, 2015 | 04:31 PM
WatsonR's Avatar
WatsonR
Learn something new every day around here..... don't spend your money on the 6.0 Power Stroke app, it doesn't have all the codes!
Old Apr 29, 2015 | 04:49 PM
dannyboy950's Avatar
dannyboy950
Thats ok I have every publicly published DTC code book up to 07 and it doesn't have that code either.
To me that TSB shows that Ford doesn't really want to have to find a actual soloution to a problem on a obsolete engine and just getting rid of the code so they don't have to deal with us.
But then I am a cranky old man. LOL
Old Apr 29, 2015 | 05:19 PM
1949ply's Avatar
1949ply
P012F
The code is P012F, my truck also is sluggish out of the hole. It seems to either point to the the FICM or installing flash 11-23-200A.
Scrpmny
Jul 20, 2017 07:48 PM
passthegaff
Feb 28, 2017 04:35 AM
gmcbride
Sep 19, 2016 01:39 PM
polosabre
Jul 29, 2014 03:13 PM
bingster
Jan 12, 2014 03:46 PM
