NP245 Question
Old Jul 17, 2017 | 07:13 PM
Nothing Special's Avatar
Nothing Special
Originally Posted by ALLFAST
Cool. He has 2, one is the 4x4 and the other is a 2 wheel drive. I'll research this. Thank for the info Franklin.
But if I'm reading what you wrote earlier, both of his trannies are 2WD units: one from a 2WD truck, the other from a 4WD "highboy" with a divorced transfer case. You need a trans from a 4WD truck that did not have a divorced transfer case.
Old Jul 17, 2017 | 07:16 PM
ALLFAST's Avatar
ALLFAST
That is probably correct, but my truck has an NP435 after all of this ! I don't know if there were delays between my update post and your post here....
Old Jul 17, 2017 | 07:20 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
NumberDummy, I really appreciate you typing out the info on the shifter tower pins. I had actually saved your response to someone from an older discussion on this very matter, so I will get new pins before I tear it apart.
The pins aren't the problem, the condition of the shift lever retainer cap is the problem, if one or both of the notches have torn out.
I've listed the shift lever retainer cap (B8T-7220-D) dozens of times here on FTE, in fact, it was the first part number I typed.
I don't recall ever selling the pins while working Ford parts counters and...no member of FTE has ever asked me about them.
Old Jul 17, 2017 | 07:25 PM
ALLFAST's Avatar
ALLFAST
I'll definitely re read the post as its been a long day ! Thanks for clarification on this.
Shawn
Old Jul 17, 2017 | 08:16 PM
Nothing Special
Sorry, I thought your goal was to get a new trans because there was something wrong with yours, not just to end up with an NP435.
Old Jul 18, 2017 | 05:07 PM
Franklin2's Avatar
Franklin2
If you are going to tear your 4x4 np435 trans apart, and possibly need some hard parts, you can certainly buy one of those 2wd 435's for cheap and tear them apart for parts. Most of the parts in the 2wd trans will work in the 4x4 trans, all except the rear housing and rear output shaft and other small pieces back there. The problem is the 2wd trans needs to be torn completely down to convert it for 4x4 use, so it's not a easy conversion.
wildstang
13
Apr 2, 2018 01:49 PM
fordguy2100
21
Mar 23, 2016 08:21 AM
redmun
Dec 13, 2013 12:54 PM
badgerrat
16
Mar 7, 2012 07:17 AM
ktownford
Mar 1, 2006 09:33 AM
