High Flow Intake Elbow?
Old Jul 10, 2017 | 02:33 PM
Amicus's Avatar
Amicus
Gentlemen,
Just wondering if HFI elbow is worth the trouble? What are the gains? What brands do you recommend. Should I stay away from the ones on Amazon?
Thanks
Gilbert
Old Jul 10, 2017 | 03:54 PM
bismic's Avatar
bismic
There are no gains from it, from my experience anyway.
Old Jul 11, 2017 | 01:51 PM
ithaca1230's Avatar
ithaca1230
I have one on my excursion. Put it on when we did the head gaskets, turbo and ported intake. Cant say weather it does anything or not. one thing is it eliminated the butterfly thing that has to do with the egr. Engine light is always on now cause of that. No one can get it to bypass that code.
Old Jul 11, 2017 | 02:37 PM
Amicus's Avatar
Amicus
Thanks guys,
I was thinking about getting one but doesn't seem to be beneficial.
Old Jul 11, 2017 | 07:14 PM
tim.moman's Avatar
tim.moman
I just pulled the butterfly. left the shaft in place and cleaned up the elbow a little with a die grinder. Don't know if made a difference on power but made me feel better and.
Old Jul 11, 2017 | 07:38 PM
Yahiko's Avatar
Yahiko
If you have the butterfly and wanted to use the new horn then you could
just zip tie it to the EGR valve or something else in the valley after you
have remove the valve so that it does not get stuck on something and throw
a code for the getting stuck. You might be able to even remove the motor and sensor from the spaces assembly and just zip tie that in place do there is less junk.
berick
Jun 28, 2012 08:02 AM
Barkin 40s
Dec 29, 2010 07:14 AM
Schmitty133
Aug 2, 2010 09:01 AM
danocross
Apr 8, 2009 10:20 PM
StockRanger
22
Dec 17, 2003 02:55 AM
