Emissions Sensor Removal
Old Jul 12, 2017 | 03:22 PM
  #61
vjsimone's Avatar
vjsimone
Originally Posted by Dman130
1 what voltage value should I read and where is pin 29
This is the idea, but I have more exact numbers somewhere......
0.45 (450mv) is usually the mid range discussed, neither lean or rich. (Some show 0.4 - 0.6 )
Old Jul 12, 2017 | 05:02 PM
  #62
Franklin2's Avatar
Franklin2
If the system is working right, you will not read a constant voltage on the O2 sensor. It will go up and down constantly. It will read rich, the computer leans the engine, it will read lean, the computer richens the mixture, and over and over. This is how it controls the mixture of the engine, constantly bouncing back and forth.
Old Jul 13, 2017 | 07:14 AM
  #63
Dman130's Avatar
Dman130
You guys live n breath this stuff, just wow.
Old Jul 13, 2017 | 11:12 AM
  #64
vjsimone's Avatar
vjsimone
Oh, just thought of something, that bundle of wires that go behind the engine I mentioned, that houses the O2 wire, there is also a bundle of vacuum lines running next to the electrical bundle.
The vacuum lines are very, very, very, fragile.
Old Jul 14, 2017 | 06:58 AM
  #65
Dman130's Avatar
Dman130
Got it, careful and slow with this.
Old Aug 1, 2017 | 07:03 AM
  #66
Dman130's Avatar
Dman130
Ok Gents, after all your help and advice I bought a code reader and the list of codes was so extensive I had to bring it into a shop. Remember, I am a novice! Anyway I thought I should man-up and report my findings even if it is bad news. Ended up having no compression on one of the cylinders, others test results just pointed to the final decision to put a new motor in. I know, there is going to be lots of opinions on this decision but know that I bought this truck after everybody and their brother had their hands in it. Bottomline...... I just wanted to start new. So thanks for all the diagnostic advice and such, much appreciated.
Old Aug 1, 2017 | 07:47 AM
  #67
Gary Lewis's Avatar
Gary Lewis
At least you know and have a path forward.
Old Aug 1, 2017 | 08:47 AM
  #68
vjsimone's Avatar
vjsimone
Yeah, but we all learn from this as well. Your post did jog the memory, and prompt the reading on Emissions light vs Engine light.
" it started to run extremely rough, and could barely idle" We should have recommended a compression check for any rough idle scenario.....
Best of luck, thanks for reporting back, let us know how it goes.....
Old Aug 1, 2017 | 12:58 PM
  #69
82_F100_300Six's Avatar
82_F100_300Six
I could have that picture framed and hanging on my wall for artwork. Beautiful!
Old Aug 11, 2017 | 07:46 AM
  #70
Dman130's Avatar
Dman130
Ok Fellas,
Is it me or just life in the project truck world?! As you know I opted for just starting new, and thank God that I sent her in to a shop instead of me and my buddies dropping in the new motor ourselves. The new motor went in just fine but the mech could not get it to run right, long story short he pulls the motor and sends it back to Jasper with a few choice words and has now put another new new motor back it her. I should get it today, note the timeline on this issue. Wisconsin summers last about 3 months and I am missing my drive time. It would have been even longer as I do not have had the leverage his shop has to make Jasper step up and deliver another motor.
I'll follow-up when it's done, this note may just be another update considering the progress so far!
The new new one is already in, this picture is the old new one set to go back. Glad I did not try to tackle this one as my hair loss is already severe!
Old Aug 11, 2017 | 08:56 AM
  #71
CountryBumkin's Avatar
CountryBumkin
I think it was smart to go with Jasper. I (Shop I worked at) have used them several times and never had any issues with their work. But **** happens.
The warranty they give on their rebuilds is outstanding.
Old Aug 14, 2017 | 12:09 PM
  #72
Dman130's Avatar
Dman130
Hello Mike,
I appreciate the nod of approval on the Jasper motor, it was a considerable leap of faith so hearing it from a guy who actually built them is just great.
Thanks again,
Tom
Old Aug 14, 2017 | 12:39 PM
  #73
Beechkid's Avatar
Beechkid
Well, Jasper has changed in the past few years.....QA is an issue.............hope everything works out for you
Old Sep 18, 2017 | 01:15 PM
  #74
Dman130's Avatar
Dman130
With the new motor installed and running great, I opted not to put the Jet performance module back on the new one, is this item of interest to anyone out there?
mikerans
18
Mar 20, 2013 01:00 PM
eman_00
6.4L Power Stroke Diesel
Nov 29, 2010 07:15 PM
V10_Cougar
Modular V10 (6.8l)
31
Sep 26, 2007 12:12 PM
jimbob21rc
20
Jul 8, 2005 12:31 PM
foul h2o
Aug 2, 2004 09:07 AM
